Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Rigid Isolated Rectangular Footing Biaxial Bending Active Area Pressure on Soil
 LiviuM
Christmas Island
User ID: 430
Threads: 75
Likes: 3,228 in 559 posts
Given Likes: 1706
03-16-2011, 08:25 PM
Rigid Isolated Rectangular Footing Active Area Maximum Pressure on Soil
This excel file written by myself contains macro (visual basic script) that allows the user to compute maximum pressure and active area (due to detachment) for rectangular rigid isolated footings under compression and biaxial bending.
Calculation assumptions:
- Footing is infinite rigid, no bending
Functions available:
=FootPressMax(Length,Width,N,Mx,My,pX,pY) returns maximum pressure on soil
=FootAActive(Length,Width,N,Mx,My,pX,pY) returns active area
=FootPressure(Length,Width,N,Mx,My,pX,pY) returns matrix with pressures, matrix size is px*py
Length is measured in X direction; Width is measured in Y direction
N - axial force (compression always positive)
Mx - bending moment around x axis
My - bending moment around y axis
pX,pY - number of meshing points 25*25 is most of the time enough
Files included:
Rigid Isolated Footings.xls (Microsoft Office 97-2003)
Rigid Isolated Footings.xlsm (Microsoft Office 2007 or newer versions)
footing.SDB (for verification, SAP2000 V14.2.4)
footing.$2k (for verification, SAP2000 V14.2.4)
[Image: 46781262487540064585.jpg]
[-] The following 30 users Like LiviuM's post:30 users Like LiviuM's post
  â€¢ 3fan, axee1980, oanm2000, avscorreia, malc, zainseiya, Jeffrey Toledo, kowheng, aslam, melkat, planeti_x, knrsa, sasan7351, Aiyub, dinu69in, blaze, almadar12, robertsas, RANA WASEEM, we_mbm, ali akbar, bigone, danny045, AK12, Jackass, albani, Dell_Brett, ting tsai huang, pssst, shadabg
 LiviuM
Christmas Island
User ID: 430
Threads: 75
Given Likes: 1706
01-24-2012, 10:35 AM (This post was last modified: 01-24-2012, 10:45 AM by LiviuM.)
This is the first part of the explanation regarding the way the algorithm used in the above excel worksheet macros works.
This part explains the way meshing was done. And the equilibrium equation.
In few words, the footing area is meshed into equivalent joints. By using a loop, iterations are performed until no joint has uplift force (negative value). This way the contact shape is determined step by step. Equilibrium equation is evaluated each step on the contact shape.
For better understanding all calculations were done in 2D, mathcad using both programing and math formulas. Also a sap 14.2.4 model is provided for verification.
Note: Increase mesh, noPoints for closer results to direct formulas. like instead of 9 use 30.
Files included: Isolated Rigid Footing.pdf, Isolated Rigid Footing.xmcd, 1.SDB
The pdf is just a print of xmcd. Mathcad file has 14 version.
0.6 MBytes
Pass
The second part will cover the biaxial bending, this one doesn't.
[-] The following 12 users Like LiviuM's post:12 users Like LiviuM's post
  â€¢ albani, foxxx2010, RICARDI, malc, 3fan, jcbv, NBZ1400, oanm2000, Dell_Brett, pssst, jacs1976, shadabg
  Reinforced Concrete – ULS capacity under combined axial load and biaxial bending avscorreia 0 8,525 06-19-2014, 12:04 PM
Last Post: avscorreia
  Concrete: Rectangular Columns with Uniaxial Bending Analysis and Design by JEC robertsas 4 12,464 04-03-2014, 01:57 PM
Last Post: arshiakh
  Foundation: Combined Rectangular Footing Design by JEC robertsas 2 9,377 03-26-2014, 10:37 AM
  Concrete: Rectangular Columns with Biaxial Bending Analysis and Design by JEC robertsas 3 12,076 04-12-2013, 10:46 AM
  Concrete: Rectangular Footing Analysis and Design by JEC robertsas 5 13,991 10-30-2011, 10:57 AM
Last Post: uvsrao61
  design of square/rectangular isolated footing alexa 2 9,869 04-11-2011, 05:24 AM
Last Post: RANA WASEEM
