Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Foundation: Prestressed Concrete Pile Design
Thread Closed
Threads: 57
08-03-2009, 04:40 PM (This post was last modified: 12-04-2010, 06:12 AM by usman.)
[Image: 78230941324089318697.jpg]
.xls   PC Pile CAL.xls (Size: 36.5 KB / Downloads: 898)
[-] The following 54 users Like kowheng's post:54 users Like kowheng's post
  • Dell_Brett, Dell_Brett, shabe, shabe, aslam, aslam, michaelsoe, michaelsoe, kaungthant, kaungthant, aby5239, aby5239, zrilek, zrilek, SUSheikh, SUSheikh, timosi™, timosi™, phat2505, erimajus, nigema, cristi, relu59, wa_sin_29, Idwans, we_mbm, zejuan, 3fan, malc, portal61, Yuma, miquan, Jackass, isurya, Sumatra, ting tsai huang, chrono146, jamildear4u, ska51, jacs127, dquan373, levanduy, bhawk0, cason, rezart, subin91, rkce, ptqc06, blaze, farahshaheen47, yeka, utan, amiboyz, spat
 lambert
Member
Philippine
User ID: 38163
Threads: 3
Likes: 53 in 18 posts
Given Likes: 6
02-17-2012, 07:05 AM
What code of practice does the spreadsheet follow sir??? Is this applicable for solid, round or octagonal sections???
[-] The following 1 user Likes lambert's post:1 user Likes lambert's post
  • farahshaheen47
Threads: 57
02-17-2012, 07:14 AM
This spreadsheet was designed for general case.
Allowable stresses can be inputted as you want and conforming to code you use.
Any section can be design, because you have to input Area(Ag), Moment of Inertia(Ig), and Section modulus(Zg) yourself.
[-] The following 7 users Like kowheng's post:7 users Like kowheng's post
  • Dell_Brett, concreteok, Sumatra, ska51, danny045, farahshaheen47, 3fan
 lambert
Member
Philippine
User ID: 38163
Threads: 3
Given Likes: 6
02-22-2012, 03:39 PM (This post was last modified: 02-22-2012, 03:43 PM by lambert.)
Sir, I had capsulized my queries about your spreadsheet. Please help me to understand it very well because I'm not well knowledgeable in allowable stress design. I'm using Strength Design since I practice Civil Engineering. The following are my questions:
1. What is PS,HS,PI and DH stand for?.
2. Is there a general rule to estimate fci' at transfer, fci at transfer and fc at service given fc'?
3. How to determine the maximum allowable prestressing force (in kN) so that the prestressing steel will not break? Is this the same with the breaking strength on ASTM Standard?
4. How can we know if the section can adequately support the given bending moment (if there is)???. Is it by performing interaction diagram like in R.C.???
I'm using ACI and AASHTO as reference code.
  • farahshaheen47
 jacs127
Senior Member
User ID: 11255
Threads: 93
Likes: 1,667 in 225 posts
Given Likes: 605
02-22-2012, 04:52 PM
Dear Friend,
Please refer "Prestressed concrete Design" by Gerwick in which a particular chapter is devoted for prestressed pile design which will help you to understand almost every thing you want. The book is already available in the forum.
[-] The following 2 users Like jacs127's post:2 users Like jacs127's post
  • farahshaheen47, oram
 lambert
Member
Philippine
User ID: 38163
Threads: 3
Given Likes: 6
02-23-2012, 12:18 AM
Friend,
I need a brief answer to my queries for now due to lack of time to read such reference.
  • farahshaheen47
Threads: 57
02-23-2012, 01:24 AM (This post was last modified: 02-23-2012, 01:33 AM by kowheng.)
@lambert
It is just name of different pile type. You can define it with your own way. The table stored these values is designed for your convenience. You can ignore it if you input Ag, Ig, Zg manually.
From my experience together with codes in my home country(Thailand), fci = 0.6·fci' and fc = 0.45·fc'
Yes, it is the same.
No interaction diagram, just check it as beam. Critical moment, practically, is at transportation stage.
[-] The following 10 users Like kowheng's post:10 users Like kowheng's post
  • eng donny, LadaHitam, Dell_Brett, rkce, 3fan, ska51, sodapas, albani, farahshaheen47, utan
 lambert
Member
Philippine
User ID: 38163
Threads: 3
Given Likes: 6
03-22-2012, 04:39 AM
Sir Koweng,
I have one (1) question left. How to determine the moment factor for transport moment for example if we have 1, 2, 3 or 4 pick-up points???
  • farahshaheen47
Threads: 57
03-22-2012, 04:50 AM
@lambert
Do your own analysis.
[-] The following 3 users Like kowheng's post:3 users Like kowheng's post
  • albani, farahshaheen47, usman
 lambert
Member
Philippine
User ID: 38163
Threads: 3
Given Likes: 6
#10
05-21-2012, 04:04 AM (This post was last modified: 05-21-2012, 04:18 AM by lambert.)
How do we handle the case (i.e. pile capacity) when the unsupported length of the pile like in a marine structure is very high, for example the klu/r is equal to 120???
Lambert
Lambert
Pages (2): 1 2 Next »
  Concrete: Prestressed Concrete Design mowafi3m 0 7,075 02-02-2011, 08:03 PM
Last Post: mowafi3m
  Foundation: Oil Storage Tank Foundation Design duazo2009 0 8,929 01-19-2011, 02:26 AM
Last Post: duazo2009
  Foundation: Lateral Pile Analyis with PY Curves and Non-Linear Pile Properties mskhaled 4 12,556 01-01-2011, 11:02 AM
Last Post: ravisbassi
  Foundation: Deterministic Shallow Foundation Design using SPT Data robertsas 2 9,333 12-04-2010, 09:43 PM
Last Post: henrybill
  Foundation Design - Vertical Vessel/Equipment (Plant Foundation) zbizafar 1 9,206 12-02-2010, 08:07 PM
Last Post: usman
  Foundation: Assessment of Transversely Loaded Pile in Soil kowheng 6 12,962 01-24-2010, 04:31 PM
Last Post: SUSheikh
  Foundation: Pile Group Analysis - PILEGRP Ultra Zone 0 7,279 01-02-2010, 01:05 AM
Last Post: Ultra Zone
