Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Calculation Notes & Analysis Files analysis and design of 3 storey school bldg. using ETABS, MIDAS & STAAD
 uev_482
User ID: 6213
Threads: 6
Likes: 144 in 17 posts
Given Likes: 0
02-26-2011, 04:27 AM (This post was last modified: 08-29-2011, 11:50 AM by 3fan.)
analysis of 3 storey school bldg. using ETABS, MIDAS & STAAD (the project can be found in the book of SK Gosh & Fanella(Seismic & Wind Design of Concrete Bldg.)
Dear all,
This is about the analysis of 3 storey school bldg. which can be found in the book of SK Gosh and Fanella. The title of the book is Seismic and Wind Design of Concrete Bldg. I used ETABS, MIDAS & STAAD in my analysis in order to compare the results and for you guys to comment. As far as analysis and design of the project in ETABS is concerned, I was able to import the same to SAFE and Autocad Structural Detailing 2010 and was able generate drawings.
Dear all,
By the way guys, the book I was referring above can be found in the forum. Thanks.
[-] The following 68 users Like uev_482's post:68 users Like uev_482's post
  β€’ lednar_ved, malc, engrezi, mrgoodboydatdat, arrowstar, zainseiya, rendel_Β©, ISTRAKTURA, Adam Smith, vvvv, rezart, shaqee, maad59, rkce, jcoronellr, sodapas, Jeffrey Toledo, gatob, engr1900, yutt, Quantumm, sasan7351, demertis, NAUTILUS87, monter, Nilupa, tang1942, hapsea, pcworks200, blaze, ssi3k, cesar3226, nigema, batata666, joradu, ArissB, Octavio, mayur_patil, parwez007, ruaumoko, tazmania, mahfuzbangla, andersen3, faxel, ramla2002, 3fan, narendra, maijuji, cool.chummy4u, youceftli, Jackass, mgdario, duazo2009, STRAIN, pssst, relu59, mahdicivil, shawn, SCREAM7890, ykhackhack, ting tsai huang, Wijono, Batman07, TAFATNEB, sructme, versiondemo, bigone, temp1366
 vinnunsam
User ID: 3932
Threads: 34
Likes: 1,281 in 116 posts
Given Likes: 457
02-26-2011, 04:38 AM
But i cannot find the book which you are talking about with the reference of the Title of the book or the author... Any chance of you posting the forum link where i the book is..
[-] The following 1 user Likes vinnunsam's post:1 user Likes vinnunsam's post
  β€’ faxel
 usman
User ID: 59
Threads: 131
Likes: 6,571 in 671 posts
Given Likes: 4974
02-26-2011, 08:52 AM
Follow the link below for the book in the forum
[-] The following 22 users Like usman's post:22 users Like usman's post
  β€’ vinnunsam, Dell_Brett, Adam Smith, erthqkengnrβ„’, rezart, eshetu, jcoronellr, melkat, engr1900, demertis, suryabharat, spat, pcworks200, nigema, joradu, parwez007, ruaumoko, faxel, ramla2002, bigone, TAFATNEB, maijuji
 kln258
User ID: 3084
Threads: 1
Likes: 10 in 5 posts
Given Likes: 51
04-27-2011, 08:31 PM
which are the software's version?
  β€’
 benny
User ID: 748
Threads: 40
Likes: 1,481 in 127 posts
Given Likes: 84
04-28-2011, 05:40 AM
You can use MIDAS Gen v7.0.2 and ETABS v9.7.2.
Comments on ETABS model:
1. Seismic ELF is in one direction only (X-dir). No seismic load in Y-dir.
2. In the Define Mass Source, if option 3 is selected do not include the load case DEAD because you defined it as selfwt of structural members. Use option From Load if the load case DEAD is included.
3. The ct for RC structure is 0.030 and not 0.035
Comments on MIDAS Gen model:
1. You defined seismic load "eq" wherein the building is subjected to EQX and EQY at the same time, because your scale factor is 1 in both EQX and EQY.
2. You have to define EQX with scale factor of 1 in X-dir and 0.30 in Y-dir if you want to consider orthogonal effect. Without orthogonal effect the scale factor in Y-dir is 0.
3. You have to define EQY with scale factor of 0.30 in X-dir and 1 in Y-dir if you want to consider orthogonal effect. Without orthogonal effect the scale factor in X-dir is 0.
I have not thoriughly examined the two files.There must be other input data that must be corrected.
[-] The following 4 users Like benny's post:4 users Like benny's post
  β€’ aslam, Yasir, ssi3k, ykhackhack
 joradu
User ID: 14569
Threads: 14
Likes: 166 in 14 posts
Given Likes: 106
05-10-2011, 11:57 AM
Hi there. I would like to ask things about the subject please bear with me.
1.) I noticed that in the STAAD file Member Cracked Property(beam), reduction factors were used with values of 0.5 for Moment of Inertia and 1.0 for Cross Sectional Area and 1.0 for Torsion Constant, kindly someone explain or point to any references why and when we need to use this member specification and what will be the effect or the importance of using this? (same goes with the columns specification)
2.) I also noticed that nodes 2, 49 and 73 were treated as Rigid Master Nodes, again why and when and what will be the effect or the importance of using this node specification?
Thank you in advance...
[-] The following 1 user Likes joradu's post:1 user Likes joradu's post
  β€’ jagur
 uev_482
User ID: 6213
Threads: 6
Given Likes: 0
06-17-2011, 01:15 PM (This post was last modified: 06-17-2011, 02:14 PM by kowheng.)
Dear benny,
ETABS comments:
1. I only ran one direction as the book is designing beam in that direction.
3. I used ct=.035 to simulate the project discussed in the book in order to compare the results from the book and the software.
MIDAS comments:
Considering that the building's shape is regular, there is no need to use the .3 coefficient.
[-] The following 2 users Like uev_482's post:2 users Like uev_482's post
  β€’ faxel, ykhackhack
  analysis of 3 storey school bldg. using RAM SS (the project can be foun uev_482 0 7,447 07-05-2018, 08:42 AM
Last Post: uev_482
  Analysis File - STAAD PRO Time History subin91 1 9,875 09-05-2014, 02:59 AM
Last Post: subin91
  Analysis and Design example of Two Storey Building using Etabs erimajus 4 19,143 04-23-2011, 06:23 AM
Last Post: David90
  analysis of 12 storey shearwall-frame bldg. using MIDAS uev_482 0 6,731 04-16-2011, 11:53 AM
Last Post: uev_482
