Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM Standards Collections - ASTM International
Thread Closed
Threads: 1,298
Likes: 25,490 in 1,924 posts
#61
02-17-2011, 11:56 AM
Dear friend,
your standard is here, I think this is current version:
IR
  • Grunf, melkat, kowheng, pedzaquino, concreteok, parwez007, usman, malc, rkce
Threads: 1,298
#62
02-17-2011, 06:56 PM
Dear pelelo,
the requested standards are in this archive:
IR
  • melkat, usman, oanm2000, Dell_Brett, malc, pelelo, alibouafia, kowheng, kevin8107, blaze, weather
Threads: 1,298
#63
02-18-2011, 12:06 PM
ASTM D7263-2009 is here:
Good luck!
  • pelelo, Quantumm, usman, Grunf
Threads: 1,298
#64
02-18-2011, 12:10 PM
ASTM D1140:
IR
  • pelelo, tynhanh, Quantumm, usman, Adam Smith, roaming79
 fordcell
Member
User ID: 25868
Threads: 8
Likes: 138 in 22 posts
Given Likes: 134
#65
02-18-2011, 03:16 PM
Check out the D7263 here:
[-] The following 3 users Like fordcell's post:3 users Like fordcell's post
  • usman, Adam Smith, roaming79
03-02-2011, 07:27 PM
Check this link:
It´s the ASTM 5334-2010, not the 2008... I think it´s better
[-] The following 5 users Like oanm2000's post:5 users Like oanm2000's post
  • Dell_Brett, pelelo, kowheng, utan, rkce
 mz55
User ID: 18983
Threads: 9
Likes: 113 in 22 posts
Given Likes: 325
#67
03-22-2011, 08:54 AM (This post was last modified: 03-22-2011, 09:25 AM by kowheng.)
i shared it for u in:
[-] The following 1 user Likes mz55's post:1 user Likes mz55's post
  • tynhanh
Threads: 1,298
#68
03-22-2011, 07:12 PM
ASTM D5340 – 10 Standard Test Method for Airport Pavement Condition Index Surveys
Author: ASTM Committee E17 | Size: 7.3 MB | Format: PDF | Publisher: ASTM International | Year: 2010 | pages: 54
[Image: 28860276752516023505.jpg]
1.1 This test method covers the determination of airport pavement condition through visual surveys of asphalt-surfaced pavements, including porous friction courses, and plain or reinforced jointed portland cement concrete pavements, using the Pavement Condition Index (PCI) method of quantifying pavement condition.
1.2 The PCI for airport pavements was developed by the US Army Corps of Engineers through the funding provided by the U.S. Air Force (1, 2, 3).2 It is further verified and adopted by FAA (4), and the U.S. Naval Facilities Engineering Command (5).
1.3 The values stated in inch-pound units are to be regarded as standard. The values given in parentheses are mathematical conversions to SI units that are provided for information only and are not considered standard.
1.4 This standard does not purport to address all of the safety concerns, if any, associated with its use. It is the responsibility of the user of this standard to establish appropriate
safety and health practices and determine the applicability of regulatory limitations prior to use. Specific precautionary statements are given in Section 6.
  • malc, melkat, kowheng, andremsreis
Threads: 1,298
#69
03-25-2011, 06:16 PM
Hi, dear pelelo
You can find this standards :
1. ASTM D3740 – 10 Standard Practice for Minimum Requirements for Agencies Engaged in Testing and/or Inspection of Soil and Rock as Used in Engineering Design and Construction
2. ASTM D1586 – 08a Standard Test Method for Standard Penetration Test (SPT) and Split-Barrel Sampling of Soils
3. ASTM D4220 – 95 (Reapproved 2007) Standard Practices for Preserving and Transporting Soil Samples
4. ASTM D5079 – 08 Standard Practices for Preserving and Transporting Rock Core Samples
5. ASTM D5434 – 09 Standard Guide for Field Logging of Subsurface Explorations of Soil and Rock
in one archive in:
IR
  • civilteam, Grunf, ArissB, utan, kowheng, blaze, malc, pelelo
 utan
Japan
User ID: 30193
Threads: 135
Likes: 1,654 in 158 posts
Given Likes: 1732
#70
03-28-2011, 05:00 AM
Here you are:
[-] The following 3 users Like utan's post:3 users Like utan's post
  • blaze, kowheng, Grunf
Pages (11): « Previous 1 2 3 4 5 6 7 8 9 10 11 Next »
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 2,804 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,151 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 2,928 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 2,985 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,187 11-12-2023, 08:07 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,255 11-01-2023, 07:18 AM
  ASTM D2573/D2573M: Standard Test Method for Field Vane Shear Test in Saturated Fine-G poolmand 0 2,822 10-28-2023, 06:32 AM
