Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Engineering Spread Sheet For Engineers and Designers
 brass
User ID: 6948
Threads: 13
Likes: 398 in 44 posts
Given Likes: 138
12-06-2010, 10:18 PM
This excel spreadsheet is useful and used for:
- piping dimensions (150 lb, 300lb, 1500lb, 900 lb. RJT, etc),
- flange weights (150#, 300#, 400#, 1500#),
- flanges (weld neck flange, slip-on flange, threaded flange, lap joint flange, blind flange),
- tee’s and reducers (straight tee, reducing tee, conc. reducer, eccentric reducer),
- ELL’s (lap joint stub end),
- pipe spans (based on using carbon steel pipe A53-GR B filled with water),
- elliptical head dimensions (flanged and dished head ASME),
- pipe tables,
- vertical vessel platform max. bracket spacing,
- stair design notes & fixed ladder design notes,
- oblique triangles, right triangle,
- brace formulas (brace length formulas),
- weights (structural plate weight),
- girder formulas, bolts (ASTM A325 & A490 bolts and nuts),
- oversized and slotted holes,
- wrench clearance guide, washer dimensions),
- welded steel grating,
- structural tubing (square, rectangular),
- S tees - structural tees (cut from S shapes),
- W tees (cut from W shapes),
- angles,
- miscellaneous channels & standard channels,
- adding calculator,
- HP shapes, S shapes, M shapes, W shapes,
- weld-o-lets,
- screwed fittings
[-] The following 29 users Like brass's post:29 users Like brass's post
  • usman, Clouseau, cpchia, pedzaquino, robertsas, mrjoesan2, strengr, rkce, kowheng, thebeatles, sangxd80, blaze, hmwere, quatermain, hzaheer, Dell_Brett, sasan7351, dizz, eduart, dinu69in, meurus, surajdas, naster, august8, bigone, ranger, ykhackhack, K.Lee, er.shyams
 scorpion07
Albania
User ID: 550
Threads: 3
Likes: 1,366 in 104 posts
Given Likes: 277
05-06-2016, 01:28 PM
Fresh Links
[-] The following 22 users Like scorpion07's post:22 users Like scorpion07's post
  • harsono, Jackass, PinkPant, blaze, malc, shaker, Aransam, oanm2000, caifan, ykhackhack, Wijono, jcbv, hkfatfatduck, er.shyams, Dell_Brett, Trishu999, Zacha01, ssi3k, rendel_©, lasalleguy, joker™, spat
  Spread sheet for Rectangular Panels with Triangularly Distributed Loads on Tank Walls kirankumarklk 0 8,254 07-19-2013, 09:55 AM
Last Post: kirankumarklk
