Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Drawings Request [REQUEST] Flat slab
[Request] Flat slab
 axee1980
User ID: 21327
Threads: 5
Likes: 34 in 10 posts
Given Likes: 218
09-20-2010, 07:04 AM
Flat slab AutoCAD
Hi,
If anyone have a drawing of a Flat Slab with drop panels showing the reinforcement details please post it for my reference.
Thank you in advance for your kind help.
 ali akbar
User ID: 21331
Threads: 113
Likes: 491 in 83 posts
Given Likes: 927
09-20-2010, 07:10 AM
Dear my friend,
I think the best choice for you is to use CSI safe software. Model a flat slab with drop panels which is also included in the templates of the program. Then apply a loading a design that. After that you can easily use the detailing of the software to produce the detail drawing for the flat slab. You can then export them to dxf and open them in AutoCAD.
[-] The following 1 user Likes ali akbar's post:1 user Likes ali akbar's post
  • axee1980
 axee1980
User ID: 21327
Threads: 5
Given Likes: 218
09-20-2010, 09:23 AM (This post was last modified: 09-20-2010, 09:37 AM by kowheng.)
Mr. Ali Akbar,
Thank you for yr quick reply
Basically I am looking for a standard drawing to check how the reinforcement is done and presented...plan view(s) and sections.
Wish you can upload a drawing if you have one.
Moderator Notes:
 ali akbar
User ID: 21331
Threads: 113
Given Likes: 927
09-20-2010, 11:09 AM
This file may help you.
[-] The following 7 users Like ali akbar's post:7 users Like ali akbar's post
  • rendel_©, Pinkto, axee1980, kaungthant, ruaumoko, alexbv, sructme
 chigozie
User ID: 5921
Threads: 18
Likes: 657 in 257 posts
Given Likes: 1548
09-20-2010, 11:18 AM
Please do not give serpent when bread is requested for. He asked for a drawing (for a million reasons in the whole world). So please post a drawing if you have it.
Teddy
  • axee1980
 ali akbar
User ID: 21331
Threads: 113
Given Likes: 927
09-20-2010, 11:22 AM
You are right. However, he also said that he is going to know how reinforcement is done and detailed. From another side, in my post I have said, this file may help you.
Thanks
[-] The following 2 users Like ali akbar's post:2 users Like ali akbar's post
  • rendel_©, axee1980
 axee1980
User ID: 21327
Threads: 5
Given Likes: 218
09-20-2010, 07:06 PM (This post was last modified: 09-20-2010, 07:49 PM by axee1980.)
Mr. Ali Akbar,
I appreciate your time and effort. I have checked the slides and i found them to be of much help even though not exactly what I am looking for.
Have a good day
Hi,
Another thing I want to clarify:
how do I dimension the drop panel. Is it same as column strip?? I couldn't find anything on this in Australian Code.
Thnk you
 ali akbar
User ID: 21331
Threads: 113
Given Likes: 927
09-21-2010, 03:12 AM
Dear my friend,
Mainly the drop panel dimensions are sized based on the shear and some other factors. This must not be the same size as the width of your column strip. You can have a look at many concrete books posted in this forum. Find them by searching.
  • axee1980
 chigozie
User ID: 5921
Threads: 18
Given Likes: 1548
09-21-2010, 10:11 AM
axee1980 wrote:-
..how do I dimension the drop panel. Is it same as column strip?? I couldn't find anything on this in Australian Code...
Comment:-
The dimension of the drop panel will depend on the result of your analysis. This will also define the extent of the column strip, the drop panel and the span or middle/other necessary strips.
If you find that difficult to accomplish, try soft ware such as Orion and or safe. We have them in this forum.
Teddy
[-] The following 2 users Like chigozie's post:2 users Like chigozie's post
  • RedHorse, axee1980
  Re:RC flat slab kunal.sinha1977 2 6,850 09-01-2010, 02:11 PM
Last Post: kunal.sinha1977
