Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Spreadsheets for design as per IS codes
 irshad313
User ID: 12804
Threads: 10
Likes: 100 in 9 posts
Given Likes: 19
01-28-2010, 05:56 AM
uploading few spreadsheets for design as per IS codes.
.xls   BeamDesign-IS13920.xls (Size: 144.5 KB / Downloads: 1,329)
[-] The following 59 users Like irshad313's post:59 users Like irshad313's post
  • engr1900, Dell_Brett, ksnmrao, vvvv, sasan51, relu59, nileshkitey, ASCE_IBC, muhammad, hsccindia, schaduw, imano, hellokrishna20, moudgil9999, mehuljethva, kumsbama, prash_mce, lucky_b2me, PAQS, oktaa80, atul_123, seracova, duazo2009, prakash, rvkumar361, keq7803, ahmed73, deanz_75, spoolgen, trk009, rohitksoni, vangjo, hozc, isurya, sructme, pulikesi23rd, michaelsoe, Mhasan, abdalkarim, baezema, oasysz, uson, subin91, sodapas, rabzih, ambrish, chinh, sssmou, chakkara, atulkrengineer, uvsrao61, dominic, floatfree, er.shyams, Rainbow, shadabg, mosesgrace, mohcivil, spat
 engr1900
User ID: 4169
Threads: 38
Likes: 251 in 53 posts
Given Likes: 1176
01-28-2010, 06:44 AM
(01-28-2010, 05:56 AM)irshad313 Wrote: uploading few spreadsheets for design as per IS codes.
Hy
Thanks, do you have spreadsheet for Moment distribution, slab,footing , column, windload on roof truss both horizontal and vertical
byee
[-] The following 4 users Like engr1900's post:4 users Like engr1900's post
  • hsccindia, mehuljethva, prash_mce, abdalkarim
 atul_123
Junior Member
User ID: 12793
Threads: 1
Likes: 26 in 7 posts
Given Likes: 62
03-16-2010, 07:29 AM
do u have other structure element design sheets?????
[-] The following 2 users Like atul_123's post:2 users Like atul_123's post
  • michaelsoe, abdalkarim
 irshad313
User ID: 12804
Threads: 10
Given Likes: 19
07-11-2010, 06:33 AM
one more work sheet!!!!!!!! for two way slab. Click on design to give input.
.xls   slab-JG12.xls (Size: 163.5 KB / Downloads: 526)
[-] The following 19 users Like irshad313's post:19 users Like irshad313's post
  • hmwere, Adam Smith, isurya, Dell_Brett, sructme, pulikesi23rd, michaelsoe, Mhasan, abdalkarim, oasysz, sodapas, rabzih, ambrish, sssmou, uvsrao61, rvkumar361, shadabg, mohcivil, spat
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
07-11-2010, 12:49 PM
I thinks Beam design in post-1 is as per IS:456-2000 and not as per IS:13920 (code for ductile design), because as per IS:13920, design shear force shall be maximum of max. analysis shear force and shear force based on moment capacity with provided reinforcement. I think shear force based on moment capacity is not considered.
[-] The following 1 user Likes aslam's post:1 user Likes aslam's post
  • abdalkarim
 irshad313
User ID: 12804
Threads: 10
Given Likes: 19
07-12-2010, 09:38 AM
(07-11-2010, 12:49 PM)aslam Wrote: I thinks Beam design in post-1 is as per IS:456-2000 and not as per IS:13920 (code for ductile design), because as per IS:13920, design shear force shall be maximum of max. analysis shear force and shear force based on moment capacity with provided reinforcement. I think shear force based on moment capacity is not considered.
Dear Aslam,
Shear as per 13920 has been considered for shear design. For simplicity maxm of shear at each is doubled for designed instead of taking actual shear at each end.
[-] The following 1 user Likes irshad313's post:1 user Likes irshad313's post
  • abdalkarim
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Given Likes: 2168
07-12-2010, 03:24 PM
"Doubling shear" is not "simplicity" but it is very crude way. IS:13920 have equations to calculate moment capacity and shear.
  • abdalkarim
 hessian
Member
User ID: 96
Threads: 21
Likes: 102 in 13 posts
Given Likes: 25
07-13-2010, 03:25 AM
Will you post more IS code spreadsheet?? such as RC and Steel
[-] The following 1 user Likes hessian's post:1 user Likes hessian's post
  • abdalkarim
 irshad313
User ID: 12804
Threads: 10
Given Likes: 19
07-15-2010, 03:44 PM (This post was last modified: 07-15-2010, 03:53 PM by irshad313.)
(07-12-2010, 03:24 PM)aslam Wrote: "Doubling shear" is not "simplicity" but it is very crude way. IS:13920 have equations to calculate moment capacity and shear.
I have not doubled the shear, I meant that instead taking the moment capacity of each end of beam moment capacity of one end is taken and doubled. The formula given in 13920 is used. Well it can always be refined.
  • abdalkarim
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Given Likes: 2168
#10
07-15-2010, 04:19 PM
well calculation of moment capacity depends on
(1) Type of Beam section (Rectangular,L,T) based on existance of slab
(2) Doubly or singly reinforced section
(3) Position of N.Axis. etc.
  • abdalkarim
  Foundation Design Spreadsheets RedHorse 4 15,635 08-05-2010, 10:13 PM
Last Post: usman
  Steel Design spreadsheets RedHorse 3 12,564 07-08-2010, 03:54 AM
Last Post: duazo2009
  Lateral Analysis and Design Loads spreadsheets RedHorse 1 7,453 06-05-2010, 03:18 AM
Last Post: jacky899
  Masonry Design spreadsheets RedHorse 1 7,310 06-05-2010, 03:05 AM
Last Post: jacky899
  Wood Design spreadsheets RedHorse 1 7,283 06-05-2010, 03:03 AM
Last Post: jacky899
  Slab and Wall Form Design Spreadsheets according to ACI Code E123 2 8,248 05-18-2010, 10:20 PM
Last Post: highcivil
  Multiple Excel Spreadsheets - RCC Design per IS and SP34 fahim 1 27,014 04-27-2010, 11:14 AM
Last Post: fahim
