RunAsDate is a small utility that allows you to run a program in the date and time that you specify. This utility doesn't change the current system date and time of your computer, but it only injects the date/time that you specify into the desired application. You can run multiple applications simultaneously, each application works with different date and time, while the real date/time of your system continues to run normally.
You can freeze the trial period indefinitely. I used RunAsDate on Fastrak 19 and it works. And its free, too!
Download the software at :
Try it and good luck to all.
