Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Excel Worksheet Password Recovery
 babog
User ID: 4235
Threads: 13
Likes: 125 in 18 posts
Given Likes: 14
10-05-2009, 02:38 AM
Here is simple routine to recover password for worksheet (not the file password) and unprotect worksheets
-----------------------------------cut below this line------
Sub PasswordBreaker()
'Author unknown
'Breaks worksheet password protection.
Dim i As Integer, j As Integer, k As Integer
Dim l As Integer, m As Integer, n As Integer
Dim i1 As Integer, i2 As Integer, i3 As Integer
Dim i4 As Integer, i5 As Integer, i6 As Integer
On Error Resume Next
For i = 65 To 66: For j = 65 To 66: For k = 65 To 66
For l = 65 To 66: For m = 65 To 66: For i1 = 65 To 66
For i2 = 65 To 66: For i3 = 65 To 66: For i4 = 65 To 66
For i5 = 65 To 66: For i6 = 65 To 66: For n = 32 To 126
ActiveSheet.Unprotect Chr(i) & Chr(j) & Chr(k) & _
Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
If ActiveSheet.ProtectContents = False Then
MsgBox "One usable password is " & Chr(i) & Chr(j) & _
Chr(k) & Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & _
Chr(i3) & Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
Exit Sub
End If
Next: Next: Next: Next: Next: Next
End Sub
-----------------cut above this line-----------------
Procedure:
start excel
open the excel file you need to unprotect
Start Visual Basic Editor: Tools -> Macro menu -> Visual Basic Editor
Create a new module : Insert -> module
Paste the above code in the module
Close Visual Basic Editor
Run the Macro named "PasswordBreaker" from Tools -> Macro menu
This will give you a password that you can use to unprotect a worksheet
If you have multiple worksheets, you need to run the macro in each worksheet.
Enjoy
Babo G
[-] The following 47 users Like babog's post:47 users Like babog's post
  • Grunf, Grunf, Dell_Brett, Dell_Brett, Chillpill, Chillpill, oanm2000, oanm2000, Yasir, Yasir, Gabemzaman, Gabemzaman, gayosoneto, gayosoneto, binh.ce, engr1900, JIGM85, bigone, Veggeta, pousin, dinu69in, civilteam, rendel_©, jaks, blackjack, keq7803, waly76, gelbert, Arun.L, Petrit, ssi3k, aami32, ilgar, ravisbassi, jcbv, mrjoesan2, utan, yamacdere, mahfuzbangla, 3fan, we_mbm, arceon, gafi, kchatza, er.shyams, karroumk, henrybill
 Learner
User ID: 4207
Threads: 38
Likes: 889 in 112 posts
Given Likes: 126
10-05-2009, 02:55 AM (This post was last modified: 10-05-2009, 03:04 AM by Learner.)
I have tried out but it does not work. Can others who have tried out and feed back? Thanks!!
 Yasir
User ID: 206
Threads: 16
Likes: 181 in 29 posts
Given Likes: 892
10-05-2009, 12:20 PM
ya i have tried and its working for me..
 vvvv
User ID: 85
Threads: 3
Likes: 8 in 4 posts
Given Likes: 2963
10-05-2009, 01:36 PM
99richard
Works perfectly.
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42493
10-06-2009, 12:19 AM
Dear All,
another alternative:
Dell
[-] The following 15 users Like Dell_Brett's post:15 users Like Dell_Brett's post
  • vvvv, vvvv, hsccindia, hsccindia, cristi, cristi, libe, libe, vinnunsam, rendel_©, JIGM85, waly76, jcbv, mrjoesan2, adshrt
 Yasir
User ID: 206
Threads: 16
Given Likes: 892
01-04-2010, 12:22 PM
dear babog
ur subroutine works fine in some worksheets but sometimes it does not break all sheets if there are number of worksheets in a single excel file.. plzz update ur code if u can..
 mig21
User ID: 1884
Threads: 38
Likes: 821 in 133 posts
Given Likes: 389
01-04-2010, 03:12 PM
hi
i have used straxx addin for 2 yeras and they solved my problems
regards
[-] The following 3 users Like mig21's post:3 users Like mig21's post
  • Dell_Brett, Yasir, JIGM85
 dinu69in
User ID: 16081
Threads: 68
Likes: 1,507 in 138 posts
Given Likes: 1634
03-13-2010, 11:45 AM
Yasir : You have to run it in every sheet
Dell brett & Mig21 : Could you please provide the "password.xla" file which can be used in Excel 2007 and higher ? Thanks in advance.
:wacko2:
 cadtfoi
User ID: 4176
Threads: 14
Likes: 345 in 35 posts
Given Likes: 98
03-13-2010, 03:19 PM
When i have a excell worksheet protected whith a pass, first of all i trie to open it whith openoffice, in most cases the "excell" of openoficee breaks all the the pass.
All you have to do is open a xls paper in rhe openoffice, noything else.
[-] The following 2 users Like cadtfoi's post:2 users Like cadtfoi's post
  • Dell_Brett, mig21
 abhijit
User ID: 6443
Threads: 1
Likes: 88 in 11 posts
Given Likes: 47
#10
12-12-2010, 12:40 PM
code works perfectly
abhijit
[-] The following 1 user Likes abhijit's post:1 user Likes abhijit's post
  • mrjoesan2
Pages (2): 1 2 Next »
  Excel password bracker aradadi 4 12,496 11-30-2012, 05:55 PM
Last Post: ska51
  RC DESIGN WORKSHEET malee 1 9,933 09-22-2012, 08:06 AM
Last Post: adshrt
  Rebar Fixing & Anchoring Design Worksheet malee 0 6,093 09-21-2012, 04:48 AM
Last Post: malee
