Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Import beam design stresses from Staad to Excel
 blackjack
Philippine
User ID: 6184
Threads: 8
Likes: 239 in 16 posts
Given Likes: 322
02-14-2010, 05:47 PM (This post was last modified: 12-15-2010, 08:26 PM by usman.)
BEAM DESIGN FORCES FROM STAAD TO EXCEL
[Image: 05719225379231227830.jpg]
Import Beam Design Forces from STAAD to Excel using Macro code. Can be used for any type of beam member. Useful to those who would like to check the software's result using their own spreadsheet. Any suggestions on improving the embedded macro shall be appreciated.
Cheers!
[Image: 85083330429139606261.jpg]
[-] The following 22 users Like blackjack's post:22 users Like blackjack's post
  â€¢ sasan51, Dell_Brett, kowheng, ASEC, engr1900, vvvv, Albert, wa_sin_29, chenamoy, rendel_©, hsccindia, robertsas, deanz_75, HellboyRBJ, abhijit, adshrt, knrsa, Clouseau, kkgcivil, bigone, ambrish, er.shyams
 kusumoaji
User ID: 16175
Threads: 2
Likes: 1 in 1 posts
Given Likes: 1
03-14-2010, 01:14 PM
on what version of staad it can be used?
i have tried but excel shows nothing
thanks
[-] The following 1 user Likes kusumoaji's post:1 user Likes kusumoaji's post
  â€¢ bigone
 rohailiyaz
User ID: 925
Threads: 104
Likes: 1,152 in 117 posts
Given Likes: 733
03-14-2010, 04:20 PM
well it works on 05.15 and 06.23
i have tried on both it workks. may be ur missing sumthng
[-] The following 2 users Like rohailiyaz's post:2 users Like rohailiyaz's post
  â€¢ blackjack, bigone
 blackjack
Philippine
User ID: 6184
Threads: 8
Given Likes: 322
03-19-2010, 09:48 AM
it is important to note also that you need to run the staad analysis first before you can import the design forces, otherwise it will not work.
[-] The following 2 users Like blackjack's post:2 users Like blackjack's post
  â€¢ hsccindia, bigone
 usman
User ID: 59
Threads: 131
Likes: 6,571 in 671 posts
Given Likes: 4974
12-16-2010, 11:29 PM
Direct Mirror
.xls   BEAM_DESIGN FORCES_from STAAD.xls (Size: 367 KB / Downloads: 297)
[-] The following 13 users Like usman's post:13 users Like usman's post
  â€¢ Dell_Brett, lednar_ved, dinu69in, kowheng, adshrt, Clouseau, er.shyams, malc, ISTRAKTURA, bigone, duazo2009, cace-01, spat
 abhijit
User ID: 6443
Threads: 1
Likes: 88 in 11 posts
Given Likes: 47
08-20-2012, 09:42 AM
[Image: 25306948875211978050.jpg]
Completely reworked Excell to import Staad - forces , stresses & utility factor.
It has options
1) Import by Group definitions or by Beam numbers
2) Load case selector
* Only problem with Utility Factor is to get U.F. for perticular load case , you have to give " LOAD LIST " command
by default it will give maximum utility factor
* VB code is open & can be modified.
* Tested on Staad 2005 output
[Image: tips.png]
1) Run Staad analysis
2) Open Excell file
3) Select desired load Case, Units
4) Click Start , Brouse & select .STD file
[-] The following 7 users Like abhijit's post:7 users Like abhijit's post
  â€¢ malc, ISTRAKTURA, Dell_Brett, titko, monter, bigone, we_mbm
 ripach
Spain
User ID: 5230
Threads: 6
Likes: 259 in 49 posts
Given Likes: 78
06-22-2017, 04:07 PM
Links dead. Please, re-upload it.
[-] The following 2 users Like ripach's post:2 users Like ripach's post
  â€¢ hatkam, caifan
 structural
Singapore
User ID: 7169
Threads: 2
Likes: 28 in 9 posts
Given Likes: 45
06-01-2020, 06:08 AM
Links are not working. Request to please re-upload.
[-] The following 1 user Likes structural's post:1 user Likes structural's post
  â€¢ mgdario
Threads: 57
06-02-2020, 04:55 AM
Link on usman post is still valid.
Please don't request for re-uploading again.
[-] The following 4 users Like kowheng's post:4 users Like kowheng's post
  â€¢ structural, Dell_Brett, oanm2000, mohamz
 chukwuma
Nigeria
User ID: 54070
Threads: 4
Likes: 37 in 20 posts
Given Likes: 34
#10
06-29-2020, 11:10 AM
Please re-upload the link on Post #6 (abhijit). I want beam stresses with utilization ratio. Thanks
  â€¢
Pages (2): 1 2 Next »
  load on beam in excel camto2 0 5,197 03-27-2018, 04:11 PM
Last Post: camto2
  Importing Staad Support Reactions using OpenSTAAD to Excel blackjack 2 12,947 06-24-2017, 05:04 PM
Last Post: ripach
  Excel for Reduced Beam Section Design RyanRS 0 8,936 08-30-2013, 01:38 PM
Last Post: RyanRS
  Excel macro to import CSI section catalog pro LiviuM 4 12,261 07-06-2012, 05:44 AM
  Steel Beam Design - Beam Selection Tables usman 0 5,894 12-02-2010, 12:42 AM
Last Post: usman
