Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Links for Free Engineering Spreadsheets
 Veggeta
Guatemala
User ID: 114
Threads: 98
Likes: 4,273 in 520 posts
Given Likes: 403
#11
01-06-2010, 02:21 AM
Pasword work, I try with all, and they all worked...
 Yasir
User ID: 206
Threads: 16
Likes: 181 in 29 posts
Given Likes: 892
#12
01-06-2010, 06:26 AM (This post was last modified: 01-06-2010, 07:04 AM by Yasir.)
@DELL BRETT: Thx alot for ur continous co operation n correspondance... i tried same procedure but m unable still...
@ reynand_d: plzz correct me .... m using this password 010108714139083
@ALL: those who have unprotected sheets by anyway... plzz share
i can not find PT SLAB sheet in the given link which is present on Daniel Website ...
[-] The following 2 users Like Yasir's post:2 users Like Yasir's post
  • harishan65, bigone
 jacky899
User ID: 4603
Threads: 16
Likes: 412 in 44 posts
Given Likes: 476
#13
01-15-2010, 06:49 PM
Guys, you have to be very, very cautious when using the cracked Daniel T. Li spreadsheets because if those spreadsheets are cracked from the Demo versions downloaded on his site and not the ones purchased from him, then the results will not be correct. It is programmed into each one of his sample spreadsheets available for download on his website to produce erroneous results since alot of people will try to crack them.
Before using them, you need to make sure that these were provided by somebody who purchased a set. Otherwise, my word of advice is to not use them.
[-] The following 8 users Like jacky899's post:8 users Like jacky899's post
  • Dell_Brett, ruaumoko, gacella, Veggeta, kavitha, rendel_©, zonoiko, mohcivil
 dinu69in
User ID: 16081
Threads: 68
Likes: 1,507 in 138 posts
Given Likes: 1634
#14
03-16-2010, 02:44 PM
HI all
When I unprotected some of the Daniel LI spreadsheets (for example the "Wind ASCE 07-05) it got unprotected. But I can't see the forumulas in the cells. All the cells are having constant values...!!
Can anyone help me in this regard please ?
Dinu69in
[-] The following 1 user Likes dinu69in's post:1 user Likes dinu69in's post
  • mohcivil
 haze
Argentina
User ID: 166
Threads: 8
Likes: 129 in 26 posts
Given Likes: 789
#15
03-17-2010, 03:19 PM (This post was last modified: 03-17-2010, 03:22 PM by BennyP.)
Most of his newer spreadsheets are this way to keep someone from unprotecting them. Not all of the his spreadsheet are like this
Threads: 1,118
#16
03-17-2010, 03:47 PM
@dinu69in
Downloaded one more time the spreadsheets and i checked your Wind ASCE 07-05.
I can see and change every cell. Here i'm looking to 13.8 in the velocity pressure and you can see the formula.
[Image: 56884296097069043293.gif]
@haze
Your phrase sounds like "Most of cats are white. Not all cats are like this." Do you have any reference for this theory ? And please if you answer to an user even a real answer don't reply filling one more time the thread with the other user text. Use new reply.
 haze
Argentina
User ID: 166
Threads: 8
Given Likes: 789
#17
03-17-2010, 07:40 PM
I have download some of his spreadsheet from time to time over the years. I have used passware to unlock them . Some of the spreadsheets will calculate and work ok. Others the formula has been removed and just a numeric values is added. No calculation is done.
[-] The following 1 user Likes haze's post:1 user Likes haze's post
  • mohcivil
Threads: 1,118
#18
03-17-2010, 08:02 PM
I never checked the results and i don't use the spreadsheets so i suppose you're right. I can't see the connection of the password protection and the content of the cells. The protected spreadsheet give right results and only the unprotected have numeric values ?
Maybe some spreadsheets was modified or was demo from the begining and other are the full spreadsheet. If you have one working protected and without formula after removing the password i want to check so please send one.
 RedHorse
Philippine
User ID: 5670
Threads: 28
Likes: 635 in 80 posts
Given Likes: 274
#19
06-04-2010, 08:08 AM (This post was last modified: 09-24-2011, 11:06 PM by 3fan.)
to quote BennyP
"Maybe some spreadsheets was modified or was demo from the begining and other are the full spreadsheet. If you have one working protected and without formula after removing the password i want to check so please send one. "
Above statement is accurate, link below is an example of demo-ware (disabled-ware) among countless others, still protected spreadsheet/unaltered.
at any situation you need to double check your calculations.
[Image: 83560691002285667312.jpg]
[-] The following 4 users Like RedHorse's post:4 users Like RedHorse's post
  • Dell_Brett, Raktim, kowheng, bigone
Pages (2): « Previous 1 2
  Engineering with the spreadsheets by ASCE fashion 5 39,387 02-05-2019, 09:42 AM
  A lot of Engineering Spreadsheets Vufor 11 29,265 08-05-2011, 06:37 AM
Last Post: Shabbar
  Engineering spreadsheets handresy 0 6,883 08-26-2010, 05:42 AM
Last Post: handresy
