Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS A5.6/A5.6M: Specification for Copper and Copper-Alloy Electrodes for Shielded Met
Likes: 8,311 in 1,373 posts
Given Likes: 92
08-22-2023, 08:05 AM (This post was last modified: 08-26-2023, 05:53 AM by Administrator. Edit Reason: N/A )
AWS A5.6/A5.6M-2008(R2017):  Specification for Copper and Copper-Alloy Electrodes for Shielded Metal Arc Welding
| Size: 4.22 MB| Format: PDF| Quality: Original preprint| Publisher: American Welding Society, Inc. (AWS) | Year: 9th Edition, 2008 (2017)| pages: 44
[Image: 99201806100001853575.jpg]
AWS A5.6/A5.6M, 9th Edition, 2008 - Specification for Copper and Copper-Alloy Electrodes for Shielded Metal Arc Welding
This specification prescribes requirements for the classification of covered copper and copper-alloy electrodes for shielded metal arc welding. It includes compositions in which the copper content exceeds that of any other element.1
Safety and health issues and concerns are beyond the scope of this standard and therefore are not fully addressed herein. Some safety and health information can be found in the Informative Annex Clauses A5 and A10. Safety and health information is available from other sources, including, but not limited to, ANSI Z49.1, Safety in Welding, Cutting, and Allied Processes, and applicable federal and state regulations.
This specification makes use of both U.S. Customary Units and the International System of Units (SI). The measurements are not exact equivalents; therefore, each system must be used independently of the other without combining in any way when referring to material properties. The specification with the designation A5.6 uses U.S. Customary Units. The specification A5.6M uses SI Units. The latter are shown within brackets or in appropriate columns in tables and figures. Standard dimensions based on either system may be used for sizing of filler metal or packaging or both under A5.6 or A5.6M specifications
1 No attempt has been made to provide for the classification of all grades of copper and copper-alloy welding electrodes. Only the more commonly used grades have been included
  • PinkPant, babakfeyzi, kowheng
 whysx
User ID: 2025
Threads: 22
Likes: 22 in 11 posts
Given Likes: 0
08-24-2023, 05:59 AM
Wrong file attached.
Given Likes: 92
(08-24-2023, 05:59 AM)whysx Wrote: Wrong file attached.
tnx for report, replaced.
  • PinkPant
  AWS A5.12M/A5.12: Specification for Tungsten and Oxide Dispersed Tungsten Electrodes poolmand 1 3,622 09-24-2024, 07:03 AM
  AWS A5.21/A5.21M: Specification for Bare Electrodes and Rods for Surfacing poolmand 1 3,579 05-29-2024, 10:53 AM
  AWS A5.14/A5.14M: Specification for Nickel and Nickel- Alloy Bare Welding Electrodes poolmand 1 3,492 01-27-2024, 11:18 AM
  AWS J1.3/J1.3M: SPECIFICATION FOR MATERIALS USED IN RESISTANCE WELDING ELECTRODES poolmand 0 3,084 01-22-2024, 12:10 PM
  AWS A5.3/A5.3M: Specification for Aluminum and Aluminum-Alloy Electrodes for Shielde poolmand 2 2,408 08-26-2023, 06:23 AM
  AWS A5.35/A5.35M: Specification for Covered Electrodes for Underwater Wet Shielded Me poolmand 2 2,398 08-26-2023, 06:14 AM
  AWS A5.36/A5.36M: Specification for Carbon and Low-Alloy Steel Flux Cored Electrodes poolmand 0 1,499 08-23-2023, 07:30 AM
