Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Concrete: Shear Wall Design (BS8110)
 Batman07
User ID: 22745
Threads: 35
Likes: 629 in 84 posts
Given Likes: 735
02-20-2012, 11:25 AM (This post was last modified: 02-20-2012, 12:34 PM by kowheng.)
Powerful spreadsheet to design shear walls under wind plus dead load combination. Essential for stability check of reinforced concrete structure. If you spend hours calculating wall stiffnesses, ∑(kr2) etc. for reinforcement areas and concrete stresses - then this spreadsheet will reduce your design time to as little as several minutes.
[Image: 82713538647986780959.jpg]
Direct Link:
.xls   1ABCD.xls (Size: 221.5 KB / Downloads: 348)
[-] The following 34 users Like Batman07's post:34 users Like Batman07's post
  • vvvv, Umer.Aleem, ruaumoko, kowheng, Jackass, melekeen, lednar_ved, sasan7351, ebcivilea, wilson, hmwere, Trishu999, shadabg, bigone, andersen3, oreslaw, tattiya, SCREAM7890, techno, EngineerGeek, monter, blaze, ikoleci, Dell_Brett, eng donny, mowafi3m, kuro, caifan, deadmeat, Ambition, nhenxanh, mohcivil, dvng, spat
 avscorreia
Portugal
User ID: 2747
Threads: 9
Likes: 762 in 203 posts
Given Likes: 875
11-06-2012, 10:39 AM
Just on comment:
Be careful with this worksheet as it doesn't take into account the full coupling of elements that constitute each core. What it does is to simply sum the stiffness of the individual rectangular elements as if they were separate. This may lead to severe errors in the analysis!
Take a look at Zalka's book (Global structural analysis of buildings) and you'll find a consistent and easy method to evaluate the global response of your building.
[-] The following 9 users Like avscorreia's post:9 users Like avscorreia's post
  • Dell_Brett, malee, mowafi3m, student71, bigone, caifan, mohcivil, zrilek, malc
 dvng
User ID: 4902
Threads: 8
Likes: 179 in 35 posts
Given Likes: 17
12-28-2015, 07:02 AM
anyone can repost the link. Link seems to be dead or inactive.
  Shear Wall ACI camto2 0 5,887 06-10-2018, 11:01 AM
Last Post: camto2
  Shear Wall EC2/EC8 camto2 0 5,497 06-14-2017, 04:16 PM
Last Post: camto2
  Analysis: Rigidity Determination for Shear Wall & Shear Wall with Opening Veggeta 3 11,117 05-09-2013, 01:23 AM
Last Post: odiclas
  Masonry: Masonry Shear Wall Design per ACI530 - DTLi Veggeta 2 9,720 12-16-2010, 11:43 PM
Last Post: usman
  Concrete: Shear Wall Design by JEC robertsas 2 8,688 12-08-2010, 12:38 AM
Last Post: usman
  Concrete: STUDRAIL v 5.0 - Shear Reinforcing Design robertsas 1 7,437 12-04-2010, 06:27 AM
Last Post: usman
  Two Way Slab (BS8110) derwin 2 7,402 09-27-2010, 10:11 AM
Last Post: RANA WASEEM
