Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Lead Rubber Bearing Properties in SAP2000
Threads: 274
Likes: 12,075 in 1,233 posts
11-12-2012, 12:46 PM
Input your data in INPUT sheet and get outputs in SAP2000 sheet.
I'm waiting for your opinion.
[Image: 87863049178975510893.png]
[Image: 72412140871154035398.png]
[-] The following 37 users Like pezhmankhan's post:37 users Like pezhmankhan's post
  β€’ Batman07, david-smith, kowheng, highcivil, seriousboy, oanm2000, Albert, Dell_Brett, ykhackhack, mary, malc, bigone, draluka, mlafonta, arceon, RyanRS, faros3000, viet2010, pfaa2020, sructme, nickycruz, ruaumoko, slowet, mohcivil, Diquan, Mohammad6299, Rodmo376, subin91, mowafi3m, ssobhan, rigid_joint, blaze, kirankumarklk, ardhiandra, hima5300, poliveira, roxanam
 ruaumoko
United Kingdom
User ID: 1110
Threads: 1
Likes: 9 in 3 posts
Given Likes: 4259
09-10-2014, 09:06 AM
Dear pezhmankhan ,
thank you very much for this useful file.
I'm wonder if you could advise where is coming the value of effective damping (0.038) of your example (tab sap2000 : for U2 & U3).
what units should have this property ?
In the input tab I couldn't find this value to see the equation used. Or is a typo and should be 0.088 ? please confirm
really appreciate your comments,
thanks in advance,
  β€’
Threads: 274
09-10-2014, 10:01 AM
Hi,
When you defined effective damping of isolators in SAP2000 (in the horizontal direction, U2 & U3), you should deduct the damping ratio of superstructure from it. Software will automatically add damping ratio of superstructure to effective damping of isolator.
So I put unit to kN-mm and after that I deductive 0.05 from effective damping to consider 5% superstructure damping.
[-] The following 5 users Like pezhmankhan's post:5 users Like pezhmankhan's post
  β€’ ruaumoko, Diquan, Mohammad6299, mowafi3m, bigone
 ruaumoko
United Kingdom
User ID: 1110
Threads: 1
Likes: 9 in 3 posts
Given Likes: 4259
09-10-2014, 10:42 AM
Thanks for your time ! pezhmankhan,
This mean, the unit is a ratio in the input of SAP2000?
Im a bit confuse, when I read in the CSI knowledge base website where explains the unit of effective damping is Force-Second/Length or Force/Velocity”
I misunderstand something?
thank you very much,
[/code]
  β€’
Threads: 274
09-10-2014, 11:53 AM
Yes, You are true.
But in HOLMES spreadsheet they defined effective damping such this. And because this spreadsheet is written by Trver Kelly, I am sure that this way is true.
  β€’ Mohammad6299, ruaumoko, mowafi3m, bigone, monter
