Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BLUE BOOK
BLUE BOOK
 Nedian
User ID: 5387
Threads: 4
Likes: 25 in 6 posts
Given Likes: 188
08-28-2009, 04:02 PM (This post was last modified: 11-03-2010, 07:52 PM by Grunf.)
BLUE BOOK of UBC 1997
Short description:
The first edition of this Design Guide was published in 1985; it was revised in 1987 (2nd Edition), in 1992 (3rd Edition), in 1996 (4th Edition), in 1997 (5th edition) and in 2001 (6th edition). It is a basic working tool for users of BS 5950-1 Structural use of steelwork in building – Code of practice for design – Rolled and welded sections, which was first published in 1985, revised in 1990 and in 2000.
This edition is a reprint of the 6th edition, in which the section range has been updated. The tables are dual titled with the BS designation as well as the Advance (open sections), Celsius® (hot finished hollow sections) or Hybox® (cold formed hollow sections) branding.
The following structural sections are covered in this publication:
• Universal beams, Universal columns, joists, bearing piles, parallel flange channels, and
structural tees cut from Universal beams and Universal columns to BS 4-1
• ASB (asymmetric beams) Slimdek® beam produced by Corus (see Corus brochure, Advance™ sections, 09/2006))
• Equal and Unequal angles to BS EN 10056-1
• Hot-finished structural hollow sections to BS EN 10210-2
• Cold-formed structural hollow sections to BS EN 10219-2
Section ranges listed are intended to be in line with sections that are readily available at the time of printing. Some sections, which are readily available but not listed in the above standards, are also included; these sections are designated by “+” in the tables.
The editorial work for the 7th Edition was carried out by Miss E Nunez Moreno, based on the 6th edition produced by Mr A Way and Mr A S Malik, with technical assistance from Mr C M King of the SCI and Mr J C Taylor, formerly of the SCI. The 6th edition was coordinated by Mr D G Brown, of the SCI, and Mr P J Williams, formerly of the BCSA.
This publication has been jointly funded by SCI and BCSA. Acknowledgement is also given to
Corus for its support for the work leading to the preparation of the initial formulae on which the capacity tables are based.
Screenshot:
[Image: 6r3ov1e9hvidhrsdwa4k.png]
Download Link:
Moderator note:
Thread moved from request section. (G)
 ahphuah
User ID: 1592
Threads: 5
Likes: 149 in 11 posts
Given Likes: 28
09-09-2009, 05:07 PM (This post was last modified: 09-09-2009, 05:29 PM by ahphuah.)
Here is the blue book, most updated version, i.e. 7th ed. Fully decryped and printable.
[-] The following 18 users Like ahphuah's post:18 users Like ahphuah's post
  • zrilek, zrilek, ruaumoko, ruaumoko, Dell_Brett, Dell_Brett, essam2109, essam2109, Parana34, Parana34, jcoronellr, jorgepereirab, u4406014, YeiYei, chenamoy, Batman07, r3be1, lednar_ved
 noelda2
User ID: 466
Threads: 21
Likes: 387 in 29 posts
Given Likes: 26
10-05-2009, 01:03 AM (This post was last modified: 10-05-2009, 01:46 AM by Dell_Brett.)
(Post Edited)
I hope this will keep you happy......
[-] The following 2 users Like noelda2's post:2 users Like noelda2's post
  • u4406014, r3be1
Away  preceptor
Senior Member
User ID: 8148
Threads: 113
Likes: 1,499 in 170 posts
Given Likes: 44
12-02-2009, 08:14 PM (This post was last modified: 04-03-2010, 06:12 PM by Grunf.)
1999 Recommended Lateral Force Requirements and Commentary (SEAOC Blue Book)
[Image: 09833126848153914617.jpg]
Description
From the Structural Engineers Association of California (SEAOC)
Recommended Lateral Force Requirements and Commentary is also known as the SEAOC Blue Book. This new 1999 Edition from SEAOC reviews recommended provisions for earthquake-resistant design of structures. Highlights include design requirements, structural tests and inspections, foundations, and recommended modifications to the 1997 Uniform Building Code for reinforced concrete, reinforced masonry, structural steel, and wood.
Author: Structural Engineers Association of California
Format: Softcover
Copyright: 1999
Pages: 440
Edit reason: Deleted dead link. (G)
[-] The following 21 users Like preceptor's post:21 users Like preceptor's post
  • essam2109, Ultra Zone, Dell_Brett, robertsas, miquan, kowheng, ascetic19, subin91, vvvv, junaid, henrycv, yutt, Thanhtung, lanz, levanduy, rohailiyaz, mad_world, soringer, civilteam, august8, deadlord
 red_pool61
User ID: 165
Likes: 522 in 61 posts
Given Likes: 320
12-11-2009, 07:14 PM (This post was last modified: 04-03-2010, 06:15 PM by Grunf.)
Edit reason: Deleted quote of previously deleted request post. (G)
[-] The following 19 users Like red_pool61's post:19 users Like red_pool61's post
  • Dell_Brett, henrycv, levanduy, dexter238, surajdas, sangen, wa_sin_29, civilteam, jcoronellr, Grunf, julioreptil, YeiYei, malc, hignacio43, Yasir, joradu, ruaumoko, pedzaquino, visu
  Corus sections interactive "blue book" to BS5950 asumi 3 4,697 09-05-2010, 11:14 AM
