Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Analysis: Bolt Group and Bolt Stress Analysis
 usman
User ID: 59
Threads: 131
Likes: 6,571 in 671 posts
Given Likes: 4974
11-07-2010, 05:32 PM (This post was last modified: 05-06-2013, 01:33 AM by usman.)
[Image: 81477223942524046851.jpg]
ECCENTRIC LOADS ON BOLT GROUPS - FOR ONE VERTICAL ROW
ECCENTRIC LOADS ON BOLT GROUPS - FOR TWO VERTICAL ROWS
ECCENTRIC LOADS ON BOLT GROUPS - FOR THREE VERTICAL ROWS
ECCENTRIC LOADS ON BOLT GROUPS - FOR FOUR VERTICAL ROWS
Based on the Instantaneous Center of Rotation Method and Alternate Method 2 Using Table XI from AISC 9th Ed. Manual (ASD)
BOLT GROUP ANALYSIS Using the Elastic Method for up to 25 Total Bolts
BOLT GROUP ANALYSIS Using the Elastic Method for up to 75 Total Bolts
BOLT STRESS ANALYSIS
For High-Strength Bolts Subject to Tension and/or Shear Per AISC 9th Edition Manual (ASD)
735KB XLS
[-] The following 19 users Like usman's post:19 users Like usman's post
  â€¢ kowheng, Dell_Brett, bhawk0, ilgar, jcbv, pedzaquino, kg85arun, ngcanhtoan, triance, oanm2000, robertsas, goober, we_mbm, tremonti, hcardenas, virusz158, Grunf, kaci, blaze
 ykhackhack
United States
User ID: 36960
Likes: 3,670 in 707 posts
Given Likes: 8693
05-06-2013, 08:58 AM
@odiclas
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
Use forum standard password for zip file
[-] The following 7 users Like ykhackhack's post:7 users Like ykhackhack's post
  â€¢ Diquan, ting tsai huang, k2kyaw, odiclas, blaze, civilgen, spat
 ingchio
User ID: 3667
Likes: 96 in 16 posts
Given Likes: 601
05-06-2013, 12:36 PM (This post was last modified: 05-06-2013, 01:43 PM by BennyP.)
Mirror lnk:
[-] The following 5 users Like ingchio's post:5 users Like ingchio's post
  â€¢ malc, nickycruz, Andrew seah, ykhackhack, eliseo.as
  Anchor Bolt Design usman 1 14,981 02-03-2019, 02:35 AM
  Analysis: Single Cell Box Culvert - Forces Analysis kowheng 3 12,569 08-09-2017, 02:33 PM
  Pile Group Analysis for Rigid Pile Cap usman 1 10,134 05-18-2017, 09:49 PM
  CivilBay Anchor Bolt Design With Anchor Reinforcement ACI 318-08 (TRIAL) michenerpark 9 21,699 07-24-2015, 09:40 AM
Last Post: Dell_Brett
  TEK 12-03C - MSJC 2013 - Masonry Anchor Bolt Design malc 0 8,880 07-03-2014, 09:59 AM
Last Post: malc
  Analysis: 2D Frame Analysis with Pinned Base and Rigid Base usman 1 7,549 03-21-2014, 10:13 PM
Last Post: scorpion07
  Weld Group Analysis usman 1 8,555 09-18-2012, 03:59 AM
Last Post: usman
