Civil Engineering Association Software Software Product Bentley Products RAM Concept V8i 5.0.1 SELECTSeries 7
Threads: 1,118
12-22-2012, 03:10 PM
[Image: 32826255163848962478.jpg]
Version: 05.00.01.04 Date: 10/12/2012
RAM Concept is an analysis and design program that uses
the finite element method for elevated concrete floor
systems, or mat foundations. The floors or mats can be
post-tensioned concrete (PT), reinforced concrete (RC), or
hybrid (a mixture of PT and RC). Concept is extremely
powerful and allows you to design an entire floor in one
model, or design individual strips or beams.
In this context, the term β€œdesign” means that:
β€’ The user defines the following: structural geometry,
loads, load combinations, and post-tensioning layout (if
applicable).
β€’ Concept calculates (for any number of load combinations):
the required amount of reinforcement for flexure
and one-way shear according to relevant code requirements;
the stud shear reinforcement (SSR) for punching
shear, stresses for flexure, and deflections.
[Image: comments.png]
Must be installed
Bentley IEG License Service 02.00.20.01
For VIP the struceng solution in Post #4 here:
works. How to use see post #1. If you need password ask struceng.
Other users enjoy the trial and please don't ask for solution (this is only for VIP)
  β€’ cordoba123, Dell_Brett, kowheng, StaadEng, bigone, mohcivil, maad59, jokerβ„’, pedrozarth, pjcivil, Vincwilson
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
01-19-2013, 09:36 AM
Mirror RAM Concept V8i 5.0.1 SELECTSeries 7 - Size: 148.26 MB (Install File)
No limits to creativity
[-] The following 5 users Like jokerβ„’'s post:5 users Like jokerβ„’'s post
  β€’ oreslaw, Rami11, bigone, blaze, Visitante
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
01-19-2013, 03:06 PM
[-] The following 4 users Like jokerβ„’'s post:4 users Like jokerβ„’'s post
  β€’ oanm2000, Dell_Brett, samsaid, bigone
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
02-15-2013, 10:26 AM
RAM Concept V8i
(Version: 05.00.02.12 Date: 2/12/2013 FileSize: 148.37 MB)
[-] The following 7 users Like jokerβ„’'s post:7 users Like jokerβ„’'s post
  β€’ Arigato, erthqkengnrβ„’, thanhthan, samsaid, chenamoy, bigone, Dell_Brett
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
06-07-2014, 06:48 AM (This post was last modified: 06-07-2014, 07:00 AM by bigone.)
RAM Concept V8i
(Version: 05.01.01.10 Date: 2/4/2014 FileSize: 220.85 MB)
RAM Concept V8i SELECTseries 8, r5.1.1, Release Notes
Release Date: February 4, 2014
Installation Instructions:
RAM Concept V8i Release 5.1.1 can be installed side-by-side with previous release versions of Concept. There is no need to uninstall previous release versions.
Error Corrections in RAM Concept V8i Release 5.1.1
RAM Concept V8i Release 5.1.1 is a patch, containing error corrections and minor enhancements. Each issue addressed is summarized below.
Audit Design Section
When the user attempted to audit a cross section generated by a design section, an error with the message β€œProgram Error (Report Parsing Error: bad master node contents)” resulted.
Large Calc Log
RAM Concept became unresponsive when the calc log had a large amount of output.
DXF Import
The import of a dxf file with missing xrefs into RAM Concept caused a program crash in specific and rare instances.
ASCE 7-10 Wind Import
When working with lateral loads that were imported from RAM Structural System, RAM Concept always treated wind loads as service loads, even when they might be ultimate level loads.
Pre-Concept V8i Release 5.1 File Compatibility Warning:
RAM Concept V8i Release 5.1 can read all previous file formats, but writes files in a format that cannot be read by previous versions.
32 bit
64 bit
[-] The following 11 users Like bigone's post:11 users Like bigone's post
  β€’ Dell_Brett, blaze, zrilek, olgabehe, toa011, oanm2000, bridgeengineer, StaadEng, Rami11, oreslaw, yutt
 bigone
User ID: 4505
Threads: 85
Given Likes: 7145
09-17-2014, 09:21 AM (This post was last modified: 09-17-2014, 09:24 AM by bigone.)
Bentley.RAM.Concept.V8i.SS9.v05.02.00.21.x86.x64
RAM Concept 5.2 Release Notes
32 bit
64bit
LAVteam crack attached
.rar   patch.rar (Size: 2.15 MB / Downloads: 295)
[-] The following 31 users Like bigone's post:31 users Like bigone's post
  β€’ amindoxiti, Dell_Brett, wuushin, Mohammad6299, RyanRS, zrilek, raja, malc, subin91, StaadEng, bridgeengineer, Williams, TAFATNEB, Diquan, Batman07, john70, viet2010, yutt, Rami11, Vincwilson, oreslaw, Milkshake, nickycruz, ykhackhack, jokerβ„’, learner20, chenamoy, JOGAR71, positron, erthqkengnrβ„’, oanm2000
 bigone
User ID: 4505
Threads: 85
Given Likes: 7145
04-25-2015, 01:08 PM
RAM Concept V8i v05.02.01.10
[Image: 56178539487228040588.png]
32 bit
size 215.6 MB
attached
.rar   LAVTeam patch.rar (Size: 2.15 MB / Downloads: 84)
[-] The following 5 users Like bigone's post:5 users Like bigone's post
  β€’ oanm2000, Williams, karthikeyans3d, Rami11, spat
 bigone
User ID: 4505
Threads: 85
Given Likes: 7145
04-25-2015, 02:26 PM (This post was last modified: 04-25-2015, 02:26 PM by bigone.)
64 bit
[-] The following 8 users Like bigone's post:8 users Like bigone's post
  β€’ ASEC, zrilek, oanm2000, Williams, Rami11, PinkPant, monter, hawking
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
06-25-2015, 03:46 PM (This post was last modified: 06-25-2015, 03:49 PM by jokerβ„’.)
Bentley RAM Concept V8i SS9 05.02.01.10 build 02/04/2015
(x86 & x64)
[-] The following 22 users Like jokerβ„’'s post:22 users Like jokerβ„’'s post
  β€’ raja, oanm2000, amindoxiti, Andrew seah, Dell_Brett, malc, subin91, PinkPant, TAFATNEB, ykhackhack, blaze, viet2010, Diquan, pedrozarth, bao2004, Arigato, ralarcon, araza023, krishna22045, deltalead, er.shyams, spat
  Bentley RAM Concept Release 3.3 (SELECTseries 3) BennyP 0 5,946 03-26-2010, 09:16 AM
