Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM Standards Collections - ASTM International
Thread Closed
Threads: 1,252
Likes: 25,491 in 1,924 posts
#71
03-28-2011, 06:13 AM
Size: 0.15 MB | Format: PDF | Publisher: ASTM Int. | Year: 2006 | pages: 11
[Image: 11749195218811451001.jpg]
Standard Practice for Obtaining Hydrostatic or Pressure Design Basis for β€œFiberglass” (Glass-Fiber-Reinforced Thermosetting-Resin) Pipe and Fittings1
πŸ‘‰ CLICK HERE πŸ‘ˆ
[-] The following 3 users Like ir_71's post:3 users Like ir_71's post
  β€’ rohailiyaz, kowheng, malc
Threads: 1,252
#72
03-28-2011, 08:09 AM
Dear friend,
I can find only this:
D3517-04
D3567-1997
D3754-04
D2105-97
D2310-97
D2924-97
All of the standards are in one archive.
IR
  β€’ kowheng, rohailiyaz, mary
 fordcell
Member
User ID: 25868
Threads: 6
Likes: 138 in 22 posts
Given Likes: 134
#73
03-28-2011, 12:12 PM (This post was last modified: 03-28-2011, 12:18 PM by kowheng.)
You can always find it in
πŸ‘‰ CLICK HERE πŸ‘ˆ :w00t:
But seriously now you can download it from here:
[-] The following 3 users Like fordcell's post:3 users Like fordcell's post
  β€’ shaqee, malc, Ayman10
 tamboon
Indonesia
User ID: 23496
Threads: 2
Likes: 69 in 10 posts
Given Likes: 179
#74
03-28-2011, 03:04 PM
ASTM 2004 (Volume 01 ~ 15) - Complete Volumes Set
Author: ASTM | Size: 1.27 GB | Format: PDF | Publisher: ASTM | Year: 2004
Covering 15 sections and a master index:
1. Iron and Steel Products
2. Nonferrous Metal Products
3. Metals Test Methods and Analytical Procedures
4. Construction
5. Petroleum Products, Lubricants, and Fossil Fuels
6. Paints, Related Coatings, and Aromatics
7. Textiles
8. Plastics
9. Rubber
10. Electrical Insulation and Electronics
11. Water and Environmental Technology
12. Nuclear, Solar, and Geothermal Energy
13. Medical Devices and Services
14. General Methods and Instrumentation
15. General Products, Chemical Specialties, and End Use Products
16. Index to all sections and volumes
Section 00 - Index
Section 01 - Iron and Steel Products
Volume 01.01 Steel--Piping, Tubing, Fittings
Volume 01.02 Ferrous Castings; Ferroalloys
Volume 01.03 Steel--Plate, Sheet, Strip, Wire; Stainless Steel Bar
Volume 01.04 Steel--Structural, Reinforcing, Pressure Vessel, Railway
Volume 01.05 Steel--Bars, Forgings, Bearing, Chain, Springs
Volume 01.06 Coated Steel Products
Volume 01.07 Ships and Marine Technology
Volume 01.08 Fasteners; Rolling Element Bearings
Section 02 - Nonferrous Metal Products
Volume 02.01 Copper and Copper Alloys
Volume 02.02 Aluminum and Magnesium Alloys
Volume 02.03 Electrical Conductors
Volume 02.04 Nonferrous Metals--Nickel, Cobalt, Lead, Tin, Zinc, Cadmium, Precious, Reactive, Refractory Metals and Alloys; Materials for Thermostats, Electrical Heating and Resistance Contacts, and Connectors
Volume 02.05 Metallic and Inorganic Coatings; Metal Powders, Sintered P/M Structural Parts
Section 03 - Metals Test Methods and Analytical Procedures
Volume 03.01 Metals -- Mechanical Testing; Elevated and Low-Temperature Tests; Metallography
Volume 03.02 Wear and Erosion; Metal Corrosion
Volume 03.03 Nondestructive Testing
Volume 03.04 Magnetic Properties
Volume 03.05 Analytical Chemistry for Metals, Ores, and Related Materials
Volume 03.06 Molecular Spectroscopy; Surface Analysis
Section 04 - Construction
Volume 04.01 Cement; Lime; Gypsum
Volume 04.02 Concrete and Aggregates
Volume 04.03 Road and Paving Materials; Vehicle-Pavement Systems
Volume 04.04 Roofing and Waterproofing
Volume 04.05 Chemical-Resistant Nonmetallic Materials; Vitrified Clay Pipe; Concrete Pipe; Fiber-Reinforced Cement Products; Mortars and Grouts; Masonry; Precast Concrete
Volume 04.06 Thermal Insulation; Environmental Acoustics
Volume 04.07 Building Seals and Sealants; Fire Standards; Dimension Stone
Volume 04.08 Soil and Rock (I): D 420 - D 5611
Volume 04.09 Soil and Rock (II): D 5714 - latest
Volume 04.10 Wood
Volume 04.11 Building Constructions (I): E 72 - E 1670
Volume 04.12 Building Constructions (II): E 1671 - latest; Property Management Systems; Technology and Underground Utilities
Volume 04.13 Geosynthetics
Section 05 - Petroleum Products, Lubricants, and Fossil Fuels
Volume 05.01 Petroleum Products and Lubricants (I): D 56 - D 3230
Volume 05.02 Petroleum Products and Lubricants (II): D 3231 - D 5302
Volume 05.03 Petroleum Products and Lubricants (III): D 5303 - D 6553
Volume 05.04 Petroleum Products and Lubricants (IV): D 6557 - latest
Volume 05.05 Test Methods for Rating Motor, Diesel, and Aviation Fuels; Catalysts; Manufactured Carbon and Graphite Products
Volume 05.06 Gaseous Fuels; Coal and Coke
Section 06 - Paints, Related Coatings, and Aromatics
Volume 06.01Paint -- Tests for Chemical, Physical, and Optical Properties; Appearance
Volume 06.02 Paint -- Products and Applications; Protective Coatings; Pipeline Coatings
Volume 06.03 Paint -- Pigments, Drying Oils, Polymers, Resins, Naval Stores, Cellulosic Esters, and Ink Vehicles
Volume 06.04 Paint -- Solvents; Aromatic Hydrocarbons
Section 07 - Textiles
Volume 07.01 Textiles (I): D 76 - D 4391
Volume 07.02 Textiles (II): D 4393 - latest
Section 08 - Plastics
Volume 08.01 Plastics (I): D 256 - D 3159
Volume 08.02 Plastics (II): D 3222 - D 5083
Volume 08.03 Plastics (III): D 5117 - latest
Volume 08.04 Plastic Pipe and Building Products
Section 09 - Rubber
Volume 09.01 Rubber, Natural and Synthetic -- General Test Methods; Carbon Black
Volume 09.02 Rubber Products, Industrial -- Specifications and Related Test Methods; Gaskets; Tires
Section 10 - Electrical Insulation and Electronics
Volume 10.01 Electrical Insulation (I): D 69 - D 2484
Volume 10.02 Electrical Insulation (II): D 2518 - latest
Volume 10.03 Electrical Insulating Liquids and Gases; Electrical Protective Equipment
Volume 10.04 Electronics
Section 11 - Water and Environmental Technology
Volume 11.01 Water (I)
Volume 11.02 Water (II)
Volume 11.03 Atmospheric Analysis; Occupational Health and Safety; Protective Clothing
Volume 11.04 Waste Management
Volume 11.05 Pesticides; Environmental Assessment; Hazardous Substances and Oil Spill Responses
Volume 11.06 Biological Effects and Environmental Fate; Biotechnology
Section 12 - Nuclear, Solar, and Geothermal Energy
Volume 12.01 Nuclear Energy (I)
Volume 12.02 Nuclear Energy (II), Solar, and Geothermal Energy
Section 13 - Medical Devices and Services
Volume 13.01 Medical and Surgical Materials and Devices; Anesthetic and Respiratory Equipment; Pharmaceutical Application of Process Analytical Technology
Volume 13.02 Emergency Medical Services; Search and Rescue
Section 14 - General Methods and Instrumentation
Volume 14.01 Healthcare Informatics
Volume 14.02 General Test Methods; Forensic Psychophysiology; Forensic Sciences; Terminology; Conformity Assessment; Statistical Methods; Nanotechnology
Volume 14.03 Temperature Measurement
Volume 14.04 Laboratory Apparatus; Degradation of Materials; SI; Oxygen Fire Safety
Section 15 - General Products, Chemical Specialties, and End Use Products
Volume 15.01 Refractories, Activated Carbon; Advanced Ceramics
Volume 15.02 Glass; Ceramic Whitewares
Volume 15.03 Space Simulation; Aerospace and Aircraft; Composite Materials
Volume 15.04 Soaps and Other Detergents; Polishes; Leather; Resilient Floor Coverings
Volume 15.05 Engine Coolants; Halogenated Organic Solvents and Fire Extinguishing Agents; Industrial and Specialty Chemicals
Volume 15.06 Adhesives
Volume 15.07 Sports Equipment and Facilities; Pedestrian Walkway; Safety and Footwear; Amusement Rides and Devices; Consumer Products; Snow Skiing; Light Sport Aircraft; Unmanned Air Vehicle Systems; Normal and Utility Category Airplane Electrical Wiring
Volume 15.08 Sensory Evaluation; Livestock, Meat, and Poultry Evaluation Systems; Vacuum Cleaners; Security Systems and Equipment; Detention and Correctional Facilities; Food Service Equipment; Homeland Security Applications
Volume 15.09 Paper; Packaging; Flexible Barrier Materials; Business Imaging Products
DIRECT LINKS thumbup
[Image: comments.png]
Get it asap while the links are still alive
[-] The following 23 users Like tamboon's post:23 users Like tamboon's post
  β€’ Grunf, rezart, utan, Dell_Brett, faros3000, kowheng, allagui10, arceon, adshrt, malc, gulilero, almadar12, Quantumm, ikoleci, Ultra Zone, engr1900, budao, bigone, mowafi3m, Gkatzogias, kasiphonk, lednar_ved, andyspak2
 adshrt
User ID: 8297
Threads: 35
Likes: 1,203 in 114 posts
Given Likes: 364
#75
03-28-2011, 05:41 PM
Torrent link
[-] The following 5 users Like adshrt's post:5 users Like adshrt's post
  β€’ zrilek, kowheng, henrycv, Eaky, kerenski_t
Threads: 57
03-29-2011, 03:58 AM (This post was last modified: 04-20-2011, 04:16 PM by kowheng.)
Mirror Links to POST: #1
MediaFire
Rapidshare
Filesonic
Fileserve
Shragle
Uploading
Easy-share
ifile
RAR password:
[-] The following 6 users Like kowheng's post:6 users Like kowheng's post
  β€’ Grunf, malc, allagui10, parwez007, utan, engr1900
 hich
User ID: 3732
Threads: 94
Likes: 5,003 in 418 posts
Given Likes: 101
#77
04-02-2011, 11:35 AM
here
[-] The following 5 users Like hich's post:5 users Like hich's post
  β€’ kowheng, Grunf, utan, pelelo, tynhanh
Threads: 57
04-11-2011, 03:36 PM
Jumbofiles: resumable, multiple-segments download, 90 days validity from last downloading
Bufiles
RAR password:
[-] The following 4 users Like kowheng's post:4 users Like kowheng's post
  β€’ engr1900, civilteam, ranger, duazo2009
 hich
User ID: 3732
Threads: 94
Given Likes: 101
#79
04-22-2011, 09:32 AM
here
PHP Code:
http://ifile.it/7k8z0qg
  β€’ kowheng, Grunf, utan, tynhanh, ypyenpham
 hrezaei
User ID: 22264
Threads: 30
Likes: 381 in 35 posts
Given Likes: 159
#80
05-05-2011, 04:41 PM
Mirror:
[-] The following 5 users Like hrezaei's post:5 users Like hrezaei's post
  β€’ sodapas, pelelo, wanazri, utan, HungNguyen29
Pages (11): « Previous 1 2 3 4 5 6 7 8 9 10 11 Next »
  [CivilEA Exclusive] ASTM C635 C635M: Standard Specification for Manufacture, Performance, and Testing of poolmand 0 643 06-17-2026, 06:05 AM
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 3,192 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,523 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 3,298 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 3,355 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,570 11-12-2023, 08:07 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,654 11-01-2023, 07:18 AM
