01-06-2010, 02:21 AM
Pasword work, I try with all, and they all worked...
@DELL BRETT: Thx alot for ur continous co operation n correspondance... i tried same procedure but m unable still...
@ reynand_d: plzz correct me .... m using this password 010108714139083 @ALL: those who have unprotected sheets by anyway... plzz share i can not find PT SLAB sheet in the given link which is present on Daniel Website ...
01-15-2010, 06:49 PM
Guys, you have to be very, very cautious when using the cracked Daniel T. Li spreadsheets because if those spreadsheets are cracked from the Demo versions downloaded on his site and not the ones purchased from him, then the results will not be correct. It is programmed into each one of his sample spreadsheets available for download on his website to produce erroneous results since alot of people will try to crack them.
Before using them, you need to make sure that these were provided by somebody who purchased a set. Otherwise, my word of advice is to not use them.
03-16-2010, 02:44 PM
HI all
When I unprotected some of the Daniel LI spreadsheets (for example the "Wind ASCE 07-05) it got unprotected. But I can't see the forumulas in the cells. All the cells are having constant values...!! Can anyone help me in this regard please ? Regards Dinu69in
03-17-2010, 03:47 PM
@dinu69in
Downloaded one more time the spreadsheets and i checked your Wind ASCE 07-05. I can see and change every cell. Here i'm looking to 13.8 in the velocity pressure and you can see the formula. ![]() @haze Your phrase sounds like "Most of cats are white. Not all cats are like this." Do you have any reference for this theory ? And please if you answer to an user even a real answer don't reply filling one more time the thread with the other user text. Use new reply.
2.Always post in the right thread. 3.Search before to prevent duplicates. 4.Use Preview Post to check. 5.THE BEST - Use the Post Generator. 6.Use the THANKS button. 7.Don't use REPLY if no need, use New Reply. Chatting not allowed.
03-17-2010, 07:40 PM
I have download some of his spreadsheet from time to time over the years. I have used passware to unlock them . Some of the spreadsheets will calculate and work ok. Others the formula has been removed and just a numeric values is added. No calculation is done.
03-17-2010, 08:02 PM
I never checked the results and i don't use the spreadsheets so i suppose you're right. I can't see the connection of the password protection and the content of the cells. The protected spreadsheet give right results and only the unprotected have numeric values ?
Maybe some spreadsheets was modified or was demo from the begining and other are the full spreadsheet. If you have one working protected and without formula after removing the password i want to check so please send one. ![]() to quote BennyP "Maybe some spreadsheets was modified or was demo from the begining and other are the full spreadsheet. If you have one working protected and without formula after removing the password i want to check so please send one. " Above statement is accurate, link below is an example of demo-ware (disabled-ware) among countless others, still protected spreadsheet/unaltered. at any situation you need to double check your calculations. ![]() ![]() ![]() Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈 ![]() Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈 |
| Possibly Related Threads… | |||||
| Thread | Author | Replies | Views | Last Post | |
| Engineering with the spreadsheets by ASCE | fashion | 5 | 39,383 |
02-05-2019, 09:42 AM Last Post: kowheng |
| A lot of Engineering Spreadsheets | Vufor | 11 | 29,250 |
08-05-2011, 06:37 AM Last Post: Shabbar |
| Engineering spreadsheets | handresy | 0 | 6,882 |
08-26-2010, 05:42 AM Last Post: handresy |
