Civil Engineering Association eBooks Traffic Engineering Advanced Rail Geotechnology - Ballasted Track
 hich
User ID: 3732
Threads: 93
Likes: 5,003 in 418 posts
Given Likes: 101
06-04-2011, 09:24 PM
Author: Buddhima Indraratna, Wadud Salim, Cholachat Rujikiatkamjorn | Size: 56.9 MB | Format: PDF | Publisher: CRC Press | Year: Mar 2011 | pages: 432 | ISBN: 9780415669573
[Image: 01068206165611109455.jpg]
Product Description
Ballast plays a vital role in transmitting and distributing the train wheel loads to the underlying sub-ballast and subgrade. Bearing capacity of track, train speed, riding quality and passenger comfort all depend on the stability of ballast through mechanical interlocking of particles. Ballast attrition and breakage occur progressively under heavy cyclic loading, causing track deterioration and rail misalignment affecting safety, and also demanding frequent and costly track maintenance. In the absence of realistic constitutive models, the track substructure is traditionally designed using empirical approaches.
In this book, the authors present the detailed information on the strength, deformation and degradation aspects of fresh and recycled ballast under monotonic, cyclic and impact loading using innovative geotechnical testing devices. A new stress-strain constitutive model for ballast incorporating particle breakage is presented. The mathematical formulations and numerical models are validated using experimental evidence and field trials. The effectiveness of various commercially available geosynthetics for enhancing track drainage and stability is elucidated. Revised ballast gradations are presented for modern high speed trains capturing particle breakage. The book also provides extensive description of the use of geosynthetics in track design, and provides an insight to track design capturing particle degradation, fouling and drainage.
This book should prove most beneficial for final year civil engineering students and postgraduates. It is imperative for practicing railway engineers and researchers with the task of modernizing existing track designs for heavier and faster trains.
Mirror:
[-] The following 19 users Like hich's post:19 users Like hich's post
  • kowheng, utan, tomtumx, blaze, ELAHI1979, cace-01, hapsea, toa011, ibg0203, isurya, oanm2000, JJ-HH, lamkin, momo2010, monter, Jackass, gulilero, ting tsai huang, rkce
06-08-2011, 12:02 PM (This post was last modified: 12-17-2011, 02:13 PM by kowheng.)
Bookmarked PDF|RAR 58.34|51.16 MB
RAR password: KCivilEA
[-] The following 5 users Like kowheng's post:5 users Like kowheng's post
  • oanm2000, malc, gulilero, kaci, Dell_Brett
 junaid
User ID: 402
Threads: 209
Likes: 8,170 in 732 posts
Given Likes: 983
11-17-2011, 08:30 PM
Other Links:
[-] The following 5 users Like junaid's post:5 users Like junaid's post
  • gulilero, GMianG, rkce, alisial, Dell_Brett
Likes: 12,075 in 1,233 posts
06-12-2012, 10:09 AM
[-] The following 5 users Like pezhmankhan's post:5 users Like pezhmankhan's post
  • 3fan, jayborre, Dell_Brett, cesar, shadabg
12-31-2012, 12:16 PM
RAR : 18.7 mb
[-] The following 1 user Likes shadabg's post:1 user Likes shadabg's post
  • Dell_Brett
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
12-31-2012, 12:42 PM
direct link;
[-] The following 1 user Likes ssobhan's post:1 user Likes ssobhan's post
  • Mohammad6299
  The Railway Track and Its Long Term Behaviour ir_71 4 3,628 02-02-2017, 10:06 PM
  Modern Railway Track-1st Edition alisial 4 4,688 03-22-2016, 10:21 AM
Last Post: RyanRS
  Track Fundamentals ir_71 2 2,928 09-21-2013, 06:30 PM
Last Post: Mohammad6299
  Joint International Light Rail Conference mahyarov 0 1,701 10-27-2012, 07:59 AM
Last Post: mahyarov
  Highway and Rail Transit Tunnel Inspection Manual tuanpecc1 1 2,074 09-06-2012, 06:55 AM
Last Post: shadabg
  Design and Construction of Pavements and Rail Tracks Ultra Zone 3 4,531 08-22-2012, 09:47 AM
Last Post: shadabg
  PSL Book of Model Railway Track Plans ir_71 0 2,117 05-14-2011, 05:17 AM
