Civil Engineering Association eBooks Codes, Manual & Handbook ANSI/NAAMM FP 1001-07 GUIDE SPECIFICATIONS FOR DESIGN OF METAL FLAGPOLES
04-28-2011, 04:55 AM
Author: NAAMM | Size: 0.7 MB | Format: PDF | Publisher: ANSI/NAAMM | Year: 2007 | pages: 27
[Image: 34288788765409560928.jpg]
1.1 These specifications set forth the procedures for determining the design loads for metal flagpoles of hollow circular cross section.
1.2 The method for determining the wind speed and resulting wind load on the pole is part of these specifications.
1.3 The method for determining the wind load on the flag and the resulting load imposed on the pole is part of these specifications also.
1.4 Methods of analysis are given with sample calculations for a typical flagpole.
1.5 Minimum properties of materials typically used in the design of flagpoles are included.
[-] The following 20 users Like ir_71's post:20 users Like ir_71's post
  â€¢ knrsa, jcbv, melkat, malc, kowheng, Jackass, Hengki, peixoto, seriousboy, toa011, Dell_Brett, lednar_ved, tluc, salahcivil, YeiYei, dizz, monter, gulilero, sivlad, Mhasan
 CAMSECT
Cambodia
User ID: 175572
Threads: 1
Likes: 2 in 2 posts
Given Likes: 402
09-27-2020, 04:42 PM
please new link.
[-] The following 1 user Likes CAMSECT's post:1 user Likes CAMSECT's post
  â€¢ hatkam
 civilfafa
Iraq
User ID: 174183
Threads: 50
Likes: 305 in 51 posts
Given Likes: 459
09-28-2020, 08:25 AM (This post was last modified: 09-28-2020, 11:31 AM by Administrator. Edit Reason: N/A )
Please find the link:
[-] The following 11 users Like civilfafa's post:11 users Like civilfafa's post
  â€¢ melekeen, babakfeyzi, CAMSECT, Wijono, caifan, Umer.Aleem, jcbv, zrilek, PinkPant, blaze, jayborre
  ANSI/API RECOMMENDED PRACTICE 2EQ FIRST EDITION, NOVEMBER 2014 Seismic Design malc 0 1,711 08-30-2021, 06:25 AM
Last Post: malc
  MBMA: Metal Roofing Systems Design Manual - 2000 struceng 3 5,045 07-21-2019, 01:02 PM
Last Post: Nita1391
  ANSI/ASHRAE 189.1-2009: Standard for the Design of High-Performance Green Buildings oanm2000 3 4,197 09-15-2017, 01:13 PM
  ANSI/AF&PA SDPWS-2008 Special Design Provisions for Wind and Seismic with Commentary ir_71 2 3,534 05-28-2016, 12:02 PM
Last Post: PinkPant
  ANSI/AF&PA NDS-2005: National Design Specification for Wood Construction cmepe 6 6,975 03-27-2016, 03:37 AM
Last Post: RICARDI
  LRFD Guide Specifications for Design of Concrete-filled FRP Tubes for Flexural and Ax Mohammad6299 1 2,272 09-01-2014, 07:35 AM
Last Post: pezhmankhan
  ANSI/HI 9.8-1998 PUMP INTAKE DESIGN malc 0 2,175 11-19-2011, 11:36 AM
Last Post: malc
