Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Concrete: Column Slenderness Ratio
 student71
User ID: 28793
Threads: 1
Likes: 153 in 60 posts
Given Likes: 174
12-21-2010, 09:24 AM (This post was last modified: 12-21-2010, 09:16 PM by usman.)
slenderness ratio
[Image: 14154274291333660606.jpg]
Slenderness ratio of concrete columns.
Author: student71, member of CivilEA
Direct Link:
.xlsx   civilea slenderness.xlsx (Size: 429.07 KB / Downloads: 279)
[-] The following 25 users Like student71's post:25 users Like student71's post
  • zrilek, kowheng, Grunf, ssobhan, chigozie, seb3k, sasan7351, usman, robertsas, knrsa, Dell_Brett, aslam, jaks, Galileo, rkce, yyyready, wa_sin_29, bigone, odiclas, YeiYei, caifan, ruaumoko, chinaw, mohcivil, spat
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 50
Likes: 4,962 in 637 posts
Given Likes: 3500
12-22-2010, 02:51 AM
@aslam, since we are at this, do u thk there should be an effective length factor maximum limit for unbraced frame?
sinha and kim elliot do have them in their book but those figures (limit) are not in the codes (at least bs8110:2 and aci 318).
wats your opinion on this?
concrete solution advocate
[-] The following 4 users Like concreteok's post:4 users Like concreteok's post
  • robertsas, usman, blaze, aslam
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
12-22-2010, 06:53 AM
@ concreteok,
First of all, we shall not mix braced/unbraced & sway/no sway frames.
May people considers column as braced if framing beam exists and unbraced if framing beam does not exists in particular direction. But this is very approximate assumption and most of codes do not use this terms(i.e. braced/unbraced).
Most codes uses sway/no sway terms for consideration of effective length factors (slenderness). There are also some approximate formulas to estimate moments due to slenderness.
Regarding your question on limit on max. effective length factor for unbraced (may be sway) columns. Code has limit upto infinity. But you can not go upto that, because it will result in very large cross section of member with very high amount of reinforcement. Thus, member size and reinforcement will indirectly control max. effective length factor.
[-] The following 8 users Like aslam's post:8 users Like aslam's post
  • concreteok, student71, Dell_Brett, Grunf, jaks, usman, Galileo, hmwere
 student71
User ID: 28793
Threads: 1
Given Likes: 174
12-22-2010, 09:33 AM
I will say only that when i get slenderness ratio more then 4, i make changes to structure, larger cross section of column or make shear wall that will make my structure no sway. For minimum slenderness ratio i use 0,84*l, if anyone have DIN regulations they don't recommend using less then 0,84*l.
And aslam is wright people should not mix braced and sway. Braced is every structure that have system for lateral forces (shear walls, concrete core, etc), and every frame is sway frame, but in some cases there is no need to calculate like sway, because movements of joint are small, and results won't difference much from no sway.
Regards!
[-] The following 6 users Like student71's post:6 users Like student71's post
  • aslam, Grunf, jaks, usman, hmwere, scorpion07
  Concrete: Concrete Short Column Analysis and Design BennyP 5 18,649 11-07-2021, 04:31 AM
Last Post: concreteok
  Concrete Short Column Analysis and Design - EC BennyP 2 10,960 08-24-2013, 11:23 AM
Last Post: pezhmankhan
  Concrete: Rectangular Column as per ACI 318-05 knrsa 5 12,454 03-02-2011, 11:47 PM
Last Post: oanm2000
  Concrete: Circular Column as per ACI 318-05 knrsa 1 6,020 03-01-2011, 09:34 PM
Last Post: Dell_Brett
  Concrete: Rectangular Concrete Beam/Column Analysis and Design Ultra Zone 1 8,274 03-25-2010, 09:16 PM
Last Post: balboul83
