Civil Engineering Association Various Free Discussion Internet connection
Internet connection
 chigozie
User ID: 5921
Threads: 18
Likes: 657 in 257 posts
Given Likes: 1548
10-22-2010, 08:55 PM
Internet connection
I have an access to an internet connection point (wireless). The problem is that, at times, I lose connection. Computer diagnosis said that I am a bit away from the connection point even when graph of the strength of the signal show that the signal is strong enough for me to have a connection. At time, even when the signal is so low, I get uninterrupted connection. I suspect that someone or something is blocking me. Could anyone suggest to me what I am to do as to always maintain my connection (such as installing software or installing an antenna-if that exists?)
Teddy
 mdmh10
User ID: 24944
Threads: 3
Likes: 187 in 65 posts
Given Likes: 66
10-23-2010, 03:36 AM
If you suspect someone is breaking into your PERSONAL wireless connection, just change the password, or switch it to MAC specific addresses. Sometimes when too many people are accessing a specific point it will either temporarily drop you or be too slow for comfort.
If you are using a FRIENDS (a.k.a. neighbors) connection you got a sensitivity case, in which case I will not be able to help you much, I do not know of any technology to improve your access range for WiFi. N-routers are typically a bit faster and has some greater range which you may try to do if you have an agreement with them. (In the US sometimes people agree to share the payment of an internet connection as well as the access in apartments)
Cheers,
MDMH
[-] The following 1 user Likes mdmh10's post:1 user Likes mdmh10's post
  • chigozie
 Smithy
User ID: 2485
Threads: 15
Likes: 367 in 39 posts
Given Likes: 30
10-23-2010, 04:15 AM
Not sure where you live and how congested the space is by other wireless routers in your neighborhood. If you have access to the router (which I am supposing you would have otherwise it would be dangerous for you as all your transactions can be intercepted by the router owner), then the easy way would be to change the channel frequency which the signals are being transferred at. This (I am told) works in crowded areas with signal dropping too often because of interference.
Hope that would solve your problem.
Adam
[-] The following 1 user Likes Smithy's post:1 user Likes Smithy's post
  • chigozie
 chigozie
User ID: 5921
Threads: 18
Given Likes: 1548
10-23-2010, 07:09 AM
This is a public access point and I am not doing anything illegal as such have nothing to hide. So I do not have the need that someone does not snoop into it. My need is that I have a constant connection. All my secluded dealings, I do within the office, using the office internet connection. Again, I leave in a reserved area (not a congested space), though there are other users around, most of them use their own private wireless connections.
I am neither using a router as such cannot change the channel frequency from which the signals are being transmitted. Any other suggestion please.
Teddy
  [PROBLEM] Windows 10 internet response seems slow hmwere 5 8,308 04-04-2016, 10:16 PM
Last Post: Dell_Brett
  Internet Tricks Every Civilean Should Know! (only for Firefox users) Batman07 1 6,499 03-07-2011, 03:01 AM
Last Post: Batman07
  Share ur Knowledge (Internet Tips & Tricks) niki102 11 14,918 11-25-2009, 03:49 AM
Last Post: vinnunsam
