Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Masonry Design spreadsheets
 RedHorse
Philippine
User ID: 5670
Threads: 28
Likes: 635 in 80 posts
Given Likes: 274
05-31-2010, 04:26 AM (This post was last modified: 09-24-2011, 11:08 PM by 3fan.)
"unprotected sheets/Password Removed"
if u like it, buy it,
for evaluation purposes only, not for commercial use
Masonry Design.rar
contains
MasonryBeam.xls
MasonryBearingWall.xls
MasonryColumn.xls
MasonryShearWall-ACI530.xls
MasonryShearWall-UBC.xls
[Image: 35985888043314603487.jpg]
[-] The following 18 users Like RedHorse's post:18 users Like RedHorse's post
  â€¢ maad59, kowheng, Dell_Brett, salahcivil, redtony, cristi, bloodrn, planeti_x, kripal, r3be1, levanduy, wagam0200, kirananvekar, pram, BandidoTJ, majeed, chinaw, siscivil
 jacky899
User ID: 4603
Threads: 16
Likes: 412 in 44 posts
Given Likes: 476
06-05-2010, 03:05 AM
A word of warning. All of the Engineering International Spreadsheets that was cracked using Microsoft Office password recovery software will produce erroneous answers. The reason is because the original files downloaded from EngineeringInternational website that was used for cracking have several variables set as constant in every sheet (will not change according to user input). Therefore the results generated by these cracked spreadsheets will not be correct.
The spreadsheets that are bought will have all cells functioning as intended. The spreadsheets bought will not show Daniel T. Li at the top left corner of the spreadsheet.
Therefore all of the Engineering International spreadsheets available for download that shows Daniel T. Li in red text at upper left corner are incorrect!
[-] The following 4 users Like jacky899's post:4 users Like jacky899's post
  â€¢ adamsawi, erick, zipatton, chicosi
  Masonry: 18 Masonry Design spreadsheet portal61 2 12,223 01-15-2015, 03:48 PM
  Masonry: Masonry Shear Wall Design per ACI530 - DTLi Veggeta 2 9,622 12-16-2010, 11:43 PM
Last Post: usman
  Foundation Design Spreadsheets RedHorse 4 15,720 08-05-2010, 10:13 PM
Last Post: usman
  Spreadsheets for design as per IS codes irshad313 9 19,010 07-15-2010, 04:19 PM
Last Post: aslam
  Steel Design spreadsheets RedHorse 3 12,650 07-08-2010, 03:54 AM
Last Post: duazo2009
  Lateral Analysis and Design Loads spreadsheets RedHorse 1 7,516 06-05-2010, 03:18 AM
Last Post: jacky899
  Wood Design spreadsheets RedHorse 1 7,351 06-05-2010, 03:03 AM
Last Post: jacky899
