Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Steel: Design Axial Strength (Compression) AISC HSS Round
 Veggeta
Guatemala
User ID: 114
Threads: 98
Likes: 4,273 in 520 posts
Given Likes: 403
12-18-2009, 06:39 AM (This post was last modified: 12-06-2010, 03:49 AM by usman.)
DESIGN AXIAL STRENGHT (COMPRESION) AISC HSS ROUND
Table of design 4-4 Axial Strenght (Shape HSS Round) AISC Steel Construction Manual
Thirteenth Edition
It is work for any length and any K at the sense X and Y axis. The fy values can be any type of steel.
LRFD and ASD method.....
[Image: 91753623126844351827.jpg]
[-] The following 4 users Like Veggeta's post:4 users Like Veggeta's post
  â€¢ kowheng, Dell_Brett, levanduy, duazo2009
  Steel: Base Plate Design As per AISC 9th edition knrsa 1 13,483 04-01-2021, 12:39 AM
  ACI 318-08 Column Design for Axial Load only bigone 3 10,405 04-06-2014, 05:56 AM
Last Post: bigone
  AISC Shapes in XLS (from AISC website) Diquan 1 7,997 11-17-2011, 01:07 AM
Last Post: Diquan
  Table 4-1 (Profiles W) AISC Steel Construction Manual Veggeta 1 7,053 11-21-2010, 06:33 AM
Last Post: osin
  AISC/LRFD 13 ED. STEEL HOLLOW SECTION DESIGN robertsas 0 6,028 09-13-2010, 09:01 AM
Last Post: robertsas
  Steel: AISC 13th Edition Member Dimensions and Properties Viewer Ultra Zone 0 6,927 12-27-2009, 03:25 PM
Last Post: Ultra Zone
  Steel: Design Axial Strength (Compression) AISC HSS Rectangular Veggeta 0 5,348 12-18-2009, 06:42 AM
Last Post: Veggeta
