Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Concrete: Design of Slab with Beams - Direct Design Method
 robertsas
Indonesia
User ID: 655
Threads: 155
Likes: 5,665 in 416 posts
Given Likes: 3149
11-21-2009, 01:57 AM (This post was last modified: 01-06-2012, 05:43 PM by usman.)
JEC Prog - Slab_with_Beams
Slab_with_Beams
Robert Sasmita
[-] The following 20 users Like robertsas's post:20 users Like robertsas's post
  â€¢ kowheng, rohailiyaz, Administrator , jaks, tonmjr, simanta, nuttapolk, goober, nigema, wa_sin_29, cleopie71, JIGM85, deanz_75, amira, Raktim, adams, atul_123, chigozie, priyoyo, albert23rd
 ska51
User ID: 11535
Threads: 382
Likes: 9,406 in 1,251 posts
Given Likes: 4017
08-05-2010, 06:16 PM (This post was last modified: 01-06-2012, 09:17 AM by Dell_Brett.)
just another link found:
"Downstream is Weaker"
[-] The following 10 users Like ska51's post:10 users Like ska51's post
  â€¢ Dell_Brett, poite, maad59, Grunf, chigozie, robertsas, tremonti, ruaumoko, malc, duazo2009
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,039 in 2,189 posts
Given Likes: 42508
01-06-2012, 09:16 AM (This post was last modified: 01-06-2012, 09:20 AM by Dell_Brett.)
[Image: 26076144011008404891.jpg]
(Tested and working @ 06/jan/2012)
[-] The following 21 users Like Dell_Brett's post:21 users Like Dell_Brett's post
  â€¢ cowboy, albani, vvvv, ob37, almadar12, fretts08, Jackass, batata666, tommy999, floatfree, Umer.Aleem, zainseiya, hignacio43, portal61, ramla2002, kairel82, cmik, chinaw, simanta, spat, cristi
  Concrete: Slab on Grade (NZ) Batman07 4 13,451 08-15-2024, 07:55 PM
Last Post: mowafi3m
  Concrete: Two Way Concete Slab Design, METHOD 2 ACI-63 haze 1 10,089 02-11-2016, 07:19 PM
  ACI318M-08 Slab Punching Design, rev1.0 bigone 1 9,002 11-08-2014, 03:59 PM
Last Post: bigone
  design of tie beams for diffrencial settlement of 1" uzi123 0 6,001 08-17-2012, 08:04 AM
Last Post: uzi123
  Concrete: Concrete Mix Design - Nils Odemark's Method kowheng 2 11,821 08-24-2011, 09:25 PM
Last Post: Dell_Brett
  Concrete: Slab Design as per ACI 318-05 knrsa 0 6,559 03-01-2011, 07:48 PM
Last Post: knrsa
  Concrete: One Way Slab Design - ACI Code, metric units Jeffrey Toledo 1 9,771 02-23-2011, 04:59 PM
Last Post: parwez007
