Civil Engineering Association eBooks Codes, Manual & Handbook ASTM Specification for Structural Joints Using ASTM A325 or A490 Bolts (2004 & 2000)
 Ultra Zone
Senior Member
El Salvador
User ID: 195
Threads: 98
Likes: 2,410 in 167 posts
Given Likes: 2238
11-17-2009, 06:05 PM
Specification for Structural Joints Using ASTM A325 or A490 Bolts (2004 &2000)
[Image: 21240913983631083393.jpg]
This RCSC Specification is a companion to AISC 350-99 that extends coverage to the use of ASTM A325, F1852 and A490 high-strength bolts in steel-to-steel structural connections, including materials, design, installation, and inspection.
Source: The Research Council on Structural Connections (RCSC).
Follow the Rules
[-] The following 18 users Like Ultra Zone's post:18 users Like Ultra Zone's post
  â€¢ abudabeeja, kowheng, vvvv, Dell_Brett, u4406014, henrycv, salahcivil, leonelmariana, alfonsus, malc, Clouseau, zainseiya, tamboon, roaming79, Quantumm, monter, fer962933, jamildear4u
03-11-2011, 02:44 PM
Specification for Structural Joints Using High-Strength Bolts
Author: RCSC Committee A.1 | Size: 1.7 MB | Format: PDF | Publisher: RCSC | Year: 2010 | pages: 100
[Image: 42102655740804001042.jpg]
Scope
This Specification covers the design of bolted joints and the installation and inspection of the assemblies of fastener components listed in Section 1.3, the use of alternative-design fasteners as permitted in Section 2.8 and alternative washer-type indicating devices as permitted in Section 2.6.2, in structural steel joints. This Specification relates only to those aspects of the connected materials that bear upon the performance of the fastener components. The Symbols, Glossary and Appendices are a part of this Specification. Commentary:
This Specification deals principally with two strength grades of high-strength bolts, ASTM A325 and A490, and with their design, installation and inspection in structural steel joints. Equivalent fasteners, however, such as ASTM F1852 (equivalent to ASTM A325) and F2280 (equivalent to ASTM A490) twist-offtype tension-control bolt assemblies, are also covered. These provisions may not be relied upon for high-strength fasteners of other chemical composition, mechanical properties, or size. These provisions do not apply when material other than steel is included in the grip; nor are they applicable to anchor rods. This Specification relates only to the performance of fasteners in structural steel joints and those few aspects of the connected material that affect this performance. Many other aspects of connection design and fabrication are of equal importance and must not be overlooked. For more general information on design and issues relating to high-strength bolting and the connected material, refer to current steel design textbooks and the Guide to Design Criteria for Bolted and Riveted Joints, 2nd Edition (Kulak et al., 1987).
[-] The following 21 users Like ir_71's post:21 users Like ir_71's post
  â€¢ kowheng, Diquan, usman, seriousboy, Ernest0, malc, gulilero, Clouseau, cesar3226, dinu69in, tamboon, roaming79, henrycv, Quantumm, Hengki, robertsas, monter, fer962933, jamildear4u, nickycruz, TAFATNEB
 jonygut
Nicaragua
User ID: 175427
Threads: 7
Likes: 286 in 17 posts
Given Likes: 322
03-24-2021, 05:48 PM
Specification for Structural Joints Using High-Strength Bolts RCSC
[Image: 86691389763069571567.jpg]
  • Author(s): RCSC Committee A.1
  • Published By: RESEARCH COUNCIL ON STRUCTURAL CONNECTIONS
  • Published Year: June 11, 2020
  • Size: 2.00 MB
  • Quality: Original Preprint
  • Related Link:
    www.boltcouncil.org
  • Abstract: The purpose of the Research Council on Structural Connections (RCSC) is:
    (1) To stimulate and support such investigation as may be deemed necessary and valuable to determine the suitability, strength, and behavior of various types of structural
    connections;
    (2) To promote the knowledge of economical and efficient practices relating to such
    structural connections; and
    (3) To prepare and publish related specifications and such other documents as necessary
    to achieve its purpose.
[Image: comments.png]
Supersedes the August 1, 2014
[-] The following 17 users Like jonygut's post:17 users Like jonygut's post
  â€¢ melekeen, temp1366, babakfeyzi, cheosmith, Dell_Brett, kowheng, pezhmankhan, PinkPant, zrilek, Aviator, milova, malc, jcbv, mohamz, Hengki, oanm2000, mgdario
  [CivilEA Exclusive] ASTM C635 C635M: Standard Specification for Manufacture, Performance, and Testing of poolmand 0 482 06-17-2026, 06:05 AM
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 3,111 01-15-2024, 10:22 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 3,222 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 3,281 01-15-2024, 10:06 AM
  ASTM 2005 - ASTM Dictionary of ENGINEERING SCIENCE & TECHNOLOGY, 10th ed abudabeeja 2 4,769 01-23-2022, 10:22 AM
  ASTM - Mega Collection of ASTM Standards (UPDATED REGULARLY) junaid 1 3,281 11-09-2017, 11:49 PM
Last Post: usman
  ASTM 2004 Standards (Complete Set) junaid 6 4,648 01-29-2017, 06:11 PM
Last Post: junaid
