Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Request for Civil Engineering Documents [REQUEST] Report – Determination of the Fracture Energy of Concrete: A comparison of the three
[Request] Report – Determination of the Fracture Energy of Concrete: A comparison of the three
 eyad
User ID: 29815
Threads: 8
Likes: 3 in 2 posts
Given Likes: 9
02-24-2017, 10:28 AM (This post was last modified: 02-24-2017, 09:44 PM by usman. Edit Reason: N/A )
Can i get this report - Annual report year : 1998
Determination of the Fracture Energy of Concrete: A comparison of the three-point bend test on notched beam and the wedge-splitting test
Editor: Hassanzadeh, Manouchehr
Sveriges Provnings- och Forskningsinstitut - Byggnadsteknik
Author: Hansen, Ernst Jan De Place
Department of Structural Engineering and Materials, Technical University of Denmark
Author: Aassved Hansen, Einar
SINTEF
Author: Stang, Henrik
Department of Structural Engineering and Materials, Technical University of Denmark, Denmark
Abstract:
In a NORDTEST project two methods for determination of the fracture energy of concrete are compared; the Three-Point Bend Test (TPBT) and the Wedge Splitting Test (WST). The methods involve notched beams and notched, grooved cubes, respectively. The two methods are compared in relation to handling and precision (repeatability, reproducability). Concrete with a water/cement ratio of 0.43 including fly ash as well as silica fume is investigated. The results show that WST is significantly faster to work with compared to TPBT, although the sawing procedure is more time consuming. Only when using laboratory prepared specimens cast in moulds with a negative groove time can be saved. With the experimental setup used in the majority of the testing, the GF determined according to the TPBT method is generally higher than the GF determined according to the WST method. The results however seem to indicate that care should be taken in designing the supports in the beam test (TPBT) in order to minimize the resistance to axial movements.
Original language English
Number of pages 53
State Published - 1998
Thanks
Users browsing this thread: 4 Guest(s)
