Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Request for Civil Engineering Documents [REQUEST] Column Web Strength in Beam-to-Column Connection
[Request] Column Web Strength in Beam-to-Column Connection
 sluise
User ID: 18261
Threads: 7
Likes: 6 in 2 posts
Given Likes: 1
10-22-2012, 04:10 PM
Hi,
I'm searching for "Column Web Strength in Beam-to-Column Connection" Journal of the Structural Division, Vol. 99, No. 9, September 1973, pp. 1978-1984.
Thanks
Stefano
 xyxtof
Poland
User ID: 39492
Threads: 1
Likes: 34 in 4 posts
Given Likes: 10
05-01-2013, 01:00 PM
Author: D. E. Newlin and W. F. Chen | Size: 1,52 MB | Format: PDF | Quality: Scanner | Publisher: Fritz Engineering Laboratory Report No. 333.14 | Year: 1971
In the design of an interior beam-to-column connection, consideration must be given to column web stiffening. The present AISC Specifications require stiffening of the compression region of column web on the basis of two formulas.
[-] The following 3 users Like xyxtof's post:3 users Like xyxtof's post
  • oanm2000, kowheng, Umer.Aleem
  [REQUEST] Steel Column Base Plate Shear Key Calculation AP88 0 5,625 06-16-2020, 10:25 AM
Last Post: AP88
  [REQUEST] Calculatios for concrete column strengthening by concrete jacketing. knrsa 0 4,162 05-24-2014, 02:14 PM
Last Post: knrsa
