Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM D6565 - 00(2005) Standard Test Method for Determination of Water (Moisture) Con
 miquan
Vietnam
User ID: 631
Threads: 171
Likes: 3,748 in 387 posts
Given Likes: 1331
08-08-2012, 04:08 PM
ASTM D6565 - 00(2005) Standard Test Method for Determination of Water (Moisture) Content of Soil by the Time-Domain Reflectometry (TDR) Method
Author: ASTM | Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: ASTM | Year: 2005 | pages: 5
This test method covers the determination of water content (or moisture content) in soil by the use of the electromagnetic technique called Time-Domain Reflectometry (TDR)
[-] The following 9 users Like miquan's post:9 users Like miquan's post
  â€¢ st77bel, david-smith, devilmaycry, kowheng, malc, Jackass, oanm2000, lisine, peixoto
  [CivilEA Exclusive] ASTM C635 C635M: Standard Specification for Manufacture, Performance, and Testing of poolmand 0 339 06-17-2026, 06:05 AM
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 3,016 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,352 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 3,134 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 3,187 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,402 11-12-2023, 08:07 AM
  STM D6927: Standard Test Method for Marshall Stability and Flow of Asphalt Mixtures poolmand 0 2,991 11-04-2023, 10:57 AM
