Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet AISC360-05 LRFD Shear bolted connection check Excel Sheet
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
07-14-2012, 02:51 AM (This post was last modified: 07-14-2012, 02:52 AM by bigone.)
AISC360-05 LRFD Shear Plate bolted connection check Excel Sheet
Author: M.A.S. | Size: 0.50 MB | Format: Excel Sheet | Quality: Original preprint | Publisher: M.A.S. | Year: 2012 | pages: 2
[Image: 83170366337873074138.png]
[Image: 84615817831186473143.png]
AISC360-05 LRFD Shear bolted connection check Excel Sheet, for one column bolt group
[-] The following 20 users Like bigone's post:20 users Like bigone's post
  â€¢ gulilero, lednar_ved, malc, kowheng, oram, chottabhai, jcbv, Dell_Brett, oanm2000, knrsa, icmrb7777, dinu69in, araza023, eng donny, arceon, ruaumoko, mohcivil, simanta, febo927, karthikeyans3d
  Excel Sheet for Concrete Retaining Wall-Metric rami1976 0 6,519 05-02-2018, 11:48 PM
  Analysis:Egyptian Code ECP201-2008 Earthquake Lateral Forces Excel sheet bigone 1 8,336 11-15-2014, 10:18 AM
Last Post: bigone
  ACI_Check of Max. Crack width for M & N for both Rec. & T sections_ DAR excel sheet bigone 0 8,337 09-09-2013, 08:14 AM
Last Post: bigone
  UBC SEISMIC CALCULATIONS EXCEL SHEET RANA WASEEM 4 15,619 12-24-2012, 06:13 AM
Last Post: RANA WASEEM
  Analysis:ASEC7-05 / IBC2006 Earthquake Lateral Forces Excel sheet bigone 1 8,899 06-30-2012, 02:47 PM
Last Post: bigone
  Multiple Excel Spreadsheets - LRFD Albert 2 11,289 06-10-2011, 10:52 AM
Last Post: 3fan
  Steel Section - Shear Capacity Check for W, WT, HS Sections usman 0 5,653 12-03-2010, 12:22 AM
Last Post: usman
