Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM C42 / C42M - 12 Standard Test Method for Obtaining and Testing Drilled Cores and
 hich
User ID: 3732
Threads: 94
Likes: 5,003 in 418 posts
Given Likes: 101
04-28-2012, 05:10 AM
ASTM C42 / C42M - 12 Standard Test Method for Obtaining and Testing Drilled Cores and Sawed Beams of Concrete
Size: .2 MB | Format: PDF | Quality: Unspecified | Publisher: ASTM | Year: 2012
This test method covers obtaining, preparing, and testing cores drilled from concrete for length or compressive strength or splitting tensile strength determinations.
[-] The following 9 users Like hich's post:9 users Like hich's post
  • 3fan, ir_71, st77bel, Dell_Brett, Sport, Jackass, kowheng, nhim4mat2006, oanm2000
 knrsa
User ID: 82
Threads: 33
Likes: 465 in 52 posts
Given Likes: 2171
12-16-2014, 06:52 AM
ASTM C42
Author: ASTM | Size: 423 KB | Format: PDF | Quality: Scanner
[-] The following 7 users Like knrsa's post:7 users Like knrsa's post
  • Dell_Brett, PinkPant, Mohammad6299, oanm2000, utan, malc, bridgeengineer
  [CivilEA Exclusive] ASTM C635 C635M: Standard Specification for Manufacture, Performance, and Testing of poolmand 0 284 06-17-2026, 06:05 AM
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 2,981 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,320 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 3,104 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 3,153 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,366 11-12-2023, 08:07 AM
  STM D6927: Standard Test Method for Marshall Stability and Flow of Asphalt Mixtures poolmand 0 2,956 11-04-2023, 10:57 AM
