Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM D4318 – 10 Standard Test Methods for Liquid Limit, Plastic Limit, and Plasticity
 portal61
Indonesia
User ID: 12856
Threads: 66
Likes: 855 in 90 posts
Given Likes: 223
02-14-2012, 12:09 PM (This post was last modified: 12-04-2014, 01:58 PM by mybest.)
ASTM D4318 – 10 Standard Test Methods for Liquid Limit, Plastic Limit, and Plasticity Index of Soils
Size: 710 KB | Format: PDF | Quality: Original preprint | Year: 2010 | pages: 16
[Image: image.jpg]
These test methods cover the determination of the liquid limit, plastic limit, and the plasticity index of soils.
[-] The following 8 users Like portal61's post:8 users Like portal61's post
  • kowheng, Jackass, mybest, 3fan, Dell_Brett, utan, nhim4mat2006, siscivil
 f_slikken
User ID: 21091
Threads: 9
Likes: 910 in 88 posts
Given Likes: 778
12-03-2014, 12:23 PM
Hi,
Here you go:
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 15 users Like f_slikken's post:15 users Like f_slikken's post
  • zrilek, bridgeengineer, PinkPant, oanm2000, Mohammad6299, Dell_Brett, isurya, subin91, brandizzo, learner20, inge911, Evandrojr, Munykong, levanduy, siscivil
  [CivilEA Exclusive] ASTM C635 C635M: Standard Specification for Manufacture, Performance, and Testing of poolmand 0 631 06-17-2026, 06:05 AM
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 3,188 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,515 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 3,294 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 3,351 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,564 11-12-2023, 08:07 AM
  STM D6927: Standard Test Method for Marshall Stability and Flow of Asphalt Mixtures poolmand 0 3,155 11-04-2023, 10:57 AM
