Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM E1225 - 09 Standard Test Method for Thermal Conductivity of Solids by Means of the Guarded-Comparative-Longitudinal
 yakwetu
User ID: 1947
Threads: 57
Likes: 1,240 in 130 posts
Given Likes: 154
01-25-2012, 07:20 AM
ASTM E1225 - 09 Standard Test Method for Thermal Conductivity of Solids by Means of the Guarded-Comparative-Longitudinal Heat Flow Technique
[-] The following 4 users Like yakwetu's post:4 users Like yakwetu's post
  • kowheng, rendel_©, Dell_Brett, chatxxnoir
  [CivilEA Exclusive] ASTM C635 C635M: Standard Specification for Manufacture, Performance, and Testing of poolmand 0 263 06-17-2026, 06:05 AM
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 2,970 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,312 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 3,095 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 3,143 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,359 11-12-2023, 08:07 AM
  STM D6927: Standard Test Method for Marshall Stability and Flow of Asphalt Mixtures poolmand 0 2,947 11-04-2023, 10:57 AM
