Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Calculation Notes & Analysis Files SAMPLE STEEL BUILDING DESIGN
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,324 in 678 posts
Given Likes: 1668
01-21-2011, 09:41 PM (This post was last modified: 03-09-2011, 04:00 PM by Dell_Brett.)
[Image: 36883880661324792297.jpg]
[Image: 64052056887353222873.jpg]
DESIGN CALCULATIONS FOR 3-STORY OFFICE BUILDING
CONTENTS
SHEETS SUBJECT
2 CONTENTS
3 GENERAL INFORMATION
4 ARRANGEMENT
5 BASIC FRAME
6 THRU 7 FLOOR & ROOF LOADS
8 DECK SELECTION
9 THRU 15 RAIN, SNOW & LATERAL LOADS
16 THRU 70 MEMBER SELECTION - VERTICAL LOADS
71 THRU 76 ANALYSIS, ADAPTATION FOR LATERAL LOADS
77 THRU 82 BRACING, COMPRESSION MEMBER DESIGN
83 THRU 87 BRACING, TENSION MEMBER DESIGN
88 THRU 89 BASE PLATE
90 THRU 93 STAIRWELL ANALYSIS
94 THRU 112 CONNECTIONS
[-] The following 78 users Like mowafi3m's post:78 users Like mowafi3m's post
  â€¢ usman, ikoleci, nuh_civil, mastermind, Gabemzaman, rezart, lednar_ved, Dell_Brett, malc, jcoronellr, jferrer, Adam Smith, kowheng, jjmtz, gatob, ISTRAKTURA, chenamoy, Yasir, essam2109, vardan, ladjin, robertsas, duazo2009, kristoffer_89, sodapas, brass, oanm2000, lasalleguy, DamaD, carolinandra, jayborre, melkat, thebeatles, dinu69in, almadar12, toa011, Diquan, engr1900, Quantumm, pm81, zainseiya, simanta, rendel_©, jf28, monter, rkce, lucky_b2me, kerenski_t, cordoba123, ssobhan, blaze, Octavio, ilgar, parwez007, jcbv, cesar3226, rfireman, Jeffrey Toledo, Panjack39, tamboon, engrezi, goober, frogprinz, hojong, Nilupa, baikur, narendra, masafi_15, Sumatra, davegabj, shawn, agelos100, kmmh76, Jackass, SCREAM7890, pengineer, erimajus, abouferass88
 JAVA
User ID: 9235
Threads: 6
Likes: 120 in 13 posts
Given Likes: 60
01-22-2011, 07:55 PM
Calculations in Excel format can be obtained form this site.
[-] The following 36 users Like JAVA's post:36 users Like JAVA's post
  â€¢ rezart, mowafi3m, pedzaquino, DamaD, jcoronellr, Dell_Brett, jayborre, melkat, dinu69in, almadar12, seriousboy, toa011, Diquan, engr1900, Quantumm, zainseiya, lednar_ved, robertsas, monter, pm81, ssobhan, rfireman, Panjack39, engrezi, Nilupa, baikur, narendra, Sumatra, shawn, moh_towhid, ebzr, SCREAM7890, pengineer, cecus, malc, spat
  RC modelling and design sample using ETABs alexa 1 8,079 04-17-2011, 02:05 PM
Last Post: wafiullah
