Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Spread Footing Analysis and Concrete Pedestal Design
 usman
User ID: 59
Threads: 131
Likes: 6,571 in 671 posts
Given Likes: 4974
11-11-2010, 10:36 PM
[Image: 21068387311423200041.jpg]
[Image: 97795854030037579923.jpg]
[Image: 24108346558552801969.jpg]
[Image: 23359542230971214783.jpg]
Spreadsheet program written in MS-Excel for the purpose of analysis of rigid rectangular spread footings with up to 8 total piers, and for either uniaxial or biaxial resultant eccentricities. Overturning sliding, and uplift stability checks are made when applicable, and resulting gross soil bearing pressures at the four (4) corners of the footing are calculated. The maximum net soil bearing pressure is also determined.
- Individual rectangular spread footing analysis (with net pier loadings)
- Individual rectangular spread footing analysis (with breakdown of loadings)
- Multiple rectangular spread footings analysis and design (table format)
- Multiple rectangular spread footings - pier analysis (table format)
This spreadsheet assumes that the spread footing is in fact "rigid", so that the bearing pressure is distributed linearly on a homogeneous soil. (Note: the actual footing is generally not "rigid", nor is the pressure beneath it distributed linearly. However, it has been found that solutions using the assumed "rigid" concept are adequate and generally result in a conservative design.)
1.21MB XLS
[-] The following 34 users Like usman's post:34 users Like usman's post
  â€¢ Adam Smith, maad59, strengr, robertsas, Diquan, isurya, kowheng, rkce, pedzaquino, we_mbm, gatob, ravisbassi, cve_jule, brass, jcbv, Dell_Brett, ruaumoko, hzaheer, lasalleguy, goober, duazo2009, tremonti, HASH007, hcardenas, benzetch, Umer.Aleem, dinu69in, fretts08, chinaw, shalaka, mtdingen, K.Lee, floatfree, andersen3
 ALMF
User ID: 1069
Threads: 4
Likes: 493 in 61 posts
Given Likes: 39
06-29-2017, 03:41 PM
I leave here a direct link.
ALMF
[-] The following 11 users Like ALMF's post:11 users Like ALMF's post
  â€¢ floatfree, Andrew seah, malc, K.Lee, caifan, amir201, Nita1391, ranger, odiclas, nibbi, cristi
  Concrete: Concrete Short Column Analysis and Design BennyP 5 19,360 11-07-2021, 04:31 AM
Last Post: concreteok
  Footing Design to ACI camto2 0 5,773 06-09-2018, 04:47 PM
Last Post: camto2
  Foundation: Combined Trapezoidal Footing Design by JEC robertsas 2 9,216 03-26-2014, 10:39 AM
  Foundation: Combined Rectangular Footing Design by JEC robertsas 2 9,374 03-26-2014, 10:37 AM
  Concrete: Rectangular Footing Analysis and Design by JEC robertsas 5 13,984 10-30-2011, 10:57 AM
Last Post: uvsrao61
  Spread Sheets for design of highways bascojhon 0 6,906 09-17-2011, 09:59 AM
Last Post: bascojhon
  design of square/rectangular isolated footing alexa 2 9,864 04-11-2011, 05:24 AM
Last Post: RANA WASEEM
