Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Lateral Analysis and Design Loads spreadsheets
 RedHorse
Philippine
User ID: 5670
Threads: 28
Likes: 635 in 80 posts
Given Likes: 274
05-31-2010, 04:22 AM (This post was last modified: 09-24-2011, 11:08 PM by 3fan.)
Lateral Analysis and Design Loads Spreadsheets
"unprotected sheets/Password Removed"
if u like it, buy it,
for evaluation purposes only, not for commercial use
Lateral Analysis and Design Loads.rar
contains
Seismic-IBC.xls
Seismic-UBC.xls
Snow.xls
WallLateralForce-IBC.xls
WallLateralForce-UBC.xls
Wind-ASCE7.xls
Wind-UBC.xls
[Image: 92715816110600862785.jpg]
[-] The following 13 users Like RedHorse's post:13 users Like RedHorse's post
  â€¢ kowheng, ascetic19, Dell_Brett, simanta, redtony, cristi, bloodrn, levanduy, super_engineer, Galileo, isurya, majeed, ykhackhack
 jacky899
User ID: 4603
Threads: 16
Likes: 412 in 44 posts
Given Likes: 476
06-05-2010, 03:18 AM
A word of warning. All of the Engineering International Spreadsheets that was cracked using Microsoft Office password recovery software will produce erroneous answers. The reason is because the original files downloaded from EngineeringInternational website that was used for cracking have several variables set as constant in every sheet (will not change according to user input). Therefore the results generated by these cracked spreadsheets will not be correct.
The spreadsheets that are bought will have all cells functioning as intended. The spreadsheets bought will not show Daniel T. Li at the top left corner of the spreadsheet.
Therefore all of the Engineering International spreadsheets available for download that shows Daniel T. Li in red text at upper left corner are incorrect!
[-] The following 6 users Like jacky899's post:6 users Like jacky899's post
  â€¢ kirananvekar, edgar9469, ska51, BandidoTJ, roveri, ykhackhack
  UBC 97, ASCE 7-10, Eurocode 8, NZS 1170.5 Lateral Loads pezhmankhan 9 19,137 03-04-2016, 05:16 AM
Last Post: hmwere
  Analysis:Egyptian Code ECP201-2008 Earthquake Lateral Forces Excel sheet bigone 1 8,336 11-15-2014, 10:18 AM
Last Post: bigone
  Analysis:ASEC7-05 / IBC2006 Earthquake Lateral Forces Excel sheet bigone 1 8,899 06-30-2012, 02:47 PM
Last Post: bigone
  Analysis: Earthquake Lateral Forces according UBC97 bigone 3 9,707 06-27-2012, 07:47 AM
Last Post: bigone
  Loads: Seismic Story Drift Analysis - IBC 2000, 2003 & 2006 Ultra Zone 2 8,490 12-15-2010, 06:54 PM
Last Post: usman
  Foundation Design Spreadsheets RedHorse 4 15,820 08-05-2010, 10:13 PM
Last Post: usman
  Spreadsheets for design as per IS codes irshad313 9 19,263 07-15-2010, 04:19 PM
Last Post: aslam
