Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Concrete: Concrete Design Spreadsheets
 RedHorse
Philippine
User ID: 5670
Threads: 28
Likes: 635 in 80 posts
Given Likes: 274
05-29-2010, 01:38 AM (This post was last modified: 05-04-2013, 04:31 PM by usman.)
"unprotected" concrete design spreadsheets
AnchorageToConcrete.xls
CompositeMember.xls
ConcreteBeam.xls
ConcreteColumn.xls
Corbel.xls
CouplingBeam.xls
DeepBeam.xls
Friction.xls
PrestressedMember.xls
ShearWall.xls
Slab.xls
TiltupPanel.xls
exclusive for CivilEA, other spreadsheets to follow.
if u like this software buy it,
not for commercial use.
[Image: 69921759915724844176.jpg]
[-] The following 20 users Like RedHorse's post:20 users Like RedHorse's post
  â€¢ shaqee, sasan73, Dell_Brett, Pekl, aami32, maad59, drhun, kaungthant, YaqubMughal, Galileo, mrco1124, draluka, faxel, levanduy, baobab, baezema, BelialCL, chinaw, ibmarin, bigone
 jacky899
User ID: 4603
Threads: 16
Likes: 412 in 44 posts
Given Likes: 476
06-05-2010, 03:21 AM
A word of warning. All of the Engineering International Spreadsheets that was cracked using Microsoft Office password recovery software will produce erroneous answers. The reason is because the original files downloaded from EngineeringInternational website that was used for cracking have several variables set as constant in every sheet (will not change according to user input). Therefore the results generated by these cracked spreadsheets will not be correct.
The spreadsheets that are bought will have all cells functioning as intended. The spreadsheets bought will not show Daniel T. Li at the top left corner of the spreadsheet.
Therefore all of the Engineering International spreadsheets available for download that shows Daniel T. Li in red text at upper left corner are incorrect!
[-] The following 16 users Like jacky899's post:16 users Like jacky899's post
  â€¢ Dell_Brett, kirananvekar, ska51, haze, aslam, Raktim, robox514, chicosi, adamsawi, zipatton, odiclas, ykhackhack, andersen3, shadabg, bigone, cristi
Threads: 49
04-18-2013, 01:03 PM (This post was last modified: 04-18-2013, 01:05 PM by andersen3.)
another link, previous is dead now
[-] The following 12 users Like andersen3's post:12 users Like andersen3's post
  â€¢ arshiakh, pezhmankhan, chrono146, hatkam, Dell_Brett, SCREAM7890, kowheng, Andrew seah, ibmarin, viet2010, bigone, zuhalz
Threads: 274
Likes: 12,075 in 1,233 posts
04-21-2013, 04:22 AM (This post was last modified: 05-04-2013, 04:29 PM by usman.)
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 6 users Like pezhmankhan's post:6 users Like pezhmankhan's post
  â€¢ blaze, Dell_Brett, bigone, cristi, marion33, narendra
  Concrete: RC Spreadsheets V4 (RCCV4) The Concrete Centre Gabemzaman 11 38,648 02-06-2023, 01:56 PM
Last Post: chukwuma
  Concrete: Concrete Short Column Analysis and Design BennyP 5 19,357 11-07-2021, 04:31 AM
Last Post: concreteok
  Concrete: Spreadsheets to British and Eurocode V4a The Concrete Centre 3fan 5 18,313 08-13-2021, 08:32 AM
  Concrete: Spreadsheets for Concrete Design to BS 8110 and EC2 rohailiyaz 4 21,215 04-12-2014, 06:52 PM
Last Post: darebert1000
  Concrete: Concept V3 form the Concrete Centre rendel_© 2 9,776 02-11-2013, 01:24 PM
  Concrete: Design of Slab with Beams - Direct Design Method robertsas 2 10,599 01-06-2012, 09:16 AM
Last Post: Dell_Brett
  Concrete: Concrete Mix Design - Nils Odemark's Method kowheng 2 11,823 08-24-2011, 09:25 PM
