Civil Engineering Association eBooks Journals, Papers and Presentations Effects of Transverse Reinforcement and Bonded length on the Side-Blowout Capacity of Headed Reinforcement
 yucapareja
User ID: 8
Threads: 40
Likes: 870 in 135 posts
Given Likes: 381
04-28-2010, 12:18 PM (This post was last modified: 04-29-2010, 03:57 AM by concreteok.)
Hi everyone, I hope someone can upload this paper:
Title: Effects of Transverse Reinforcement and Bonded length on the Side-Blowout Capacity of Headed Reinforcement
Author(s): R. A. DeVries, J. O. Jirsa and T. Bashandy
Publication: Special Publication
Volume: 180
Pages: 367-390
Keywords: Anchorage; bonding; reinforced concrete; slip; transverse reinforcement
Date: October 1, 1998
Abstract:
Pullout tests were conducted on deeply embedded headed reinforcement to determine the effect of transverse reinforcement and bonded length on the side-blowout capacity and load-slip behavior of the anchorage. It was found that transverse ties or stirrups in the anchorage zone had little effect on the ultimate capacity. Increases in anchorage capacity were only observed when the head was positively anchored in contact behind a large crossing bar. Transverse reinforcement also had little effect on the load-slip behavior before failure. However, when large amounts of transverse reinforcement were placed near the head, the amount of load maintained after the blowout failure occurred was increased. Additional bonded length of a deformed reinforcing bar increased the anchorage capacity and reduced the head slip for a given load. The amount of increase in capacity can be predicted using current ACI provisions for development length. Design procedures taking into account the effects of transverse reinforcement and bonded length were developed.
Thanks in Advance
  â€¢
 zbizafar
User ID: 1998
Threads: 46
Likes: 889 in 86 posts
Given Likes: 333
04-29-2010, 03:14 AM
SP180-16
[-] The following 9 users Like zbizafar's post:9 users Like zbizafar's post
  â€¢ user, concreteok, robertsas, Grunf, yucapareja, pssst, oanm2000, pram, sodapas
  Design of Anchor Reinforcement for Seismic Shear Loads asim99 0 4,036 03-17-2013, 12:08 AM
  Guideline for Subgrade Reinforcement with Geosynthetics ir_71 0 4,139 06-01-2011, 04:32 PM
  Geosynthetics Reinforcement in Waste Containment Applications ir_71 0 3,679 05-30-2011, 04:50 AM
  REINFORCEMENT HANDBOOK ir_71 1 5,217 03-10-2011, 03:15 AM
Last Post: adams
  ASCE - Optimal Steel Fiber Strength for Reinforcement of Cementitious Materials datagap 1 5,385 01-23-2011, 08:44 PM
Last Post: psa_1987
  Guide for the use of stainless steel reinforcement in concrete structures ir_71 0 4,535 12-08-2010, 02:16 PM
  RECENT ADVANCES IN GROUND ANCHOR AND GROUND REINFORCEMENT TECHNOLOGY giguni 0 5,256 09-27-2010, 02:38 PM
Last Post: giguni
