Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Request for Civil Engineering Documents [REQUEST] Canals Cross Sections and Area Calculation
[Request] Canals Cross Sections and Area Calculation
 adilch
User ID: 6532
Threads: 8
Likes: 42 in 5 posts
Given Likes: 21
03-30-2012, 02:20 AM
Hi i need a spread sheet or a small software which can help me building canal cross sections with given data points preferable in CAD format, which will later help in area calculations. Or any other solution related to this problem.
I really need solution. So any kind of help will be appreciated :)
Cheers.. !
 faros3000
Senior Member
User ID: 61
Threads: 24
Likes: 1,265 in 175 posts
Given Likes: 1793
03-30-2012, 06:54 AM
(03-30-2012, 02:20 AM)adilch Wrote: ... with given data points preferable in CAD format, which will later help in area calculations.
Even better, get them directly from your CAD software! ...well, I´m asumming you are using AutoCad. Here´s the procedure:
1. Draw your sections in Autocad (I draw them in layout view). Draw them with watever units you are using (e.g., 5cm, 5mm, 5in), as it will only give you consistent ones.
2. If you used several lines, either convert them to polyline or draw a new polyline over and then erase them.
3. Make that polyline a region (=>region, then select it).
4. Go to =>Tools, then =>Inquiry, then =>Region/mass properties and select your previous region. You will be shown all properties from your section, which can be exported to a spreadsheet.
Hope that helps!
Information is not knowledge.
Albert Einstein
[-] The following 1 user Likes faros3000's post:1 user Likes faros3000's post
  • Dell_Brett
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,705 in 1,304 posts
Given Likes: 4618
03-30-2012, 09:47 AM
Here you can find detail procedure for calculating section properties in AutoCAD
