Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Calculation Notes & Analysis Files Oil Storage Tank Design Calculation as per API 650
 duazo2009
Philippine
User ID: 16207
Threads: 5
Likes: 161 in 12 posts
Given Likes: 760
01-18-2011, 06:00 PM (This post was last modified: 01-19-2011, 08:34 AM by Dell_Brett.)
Oil Storage Tank Mechanical Design Calculation AS per API 650
[-] The following 24 users Like duazo2009's post:24 users Like duazo2009's post
  • faros3000, rohailiyaz, dinu69in, rezart, lednar_ved, Dell_Brett, malc, gatob, kowheng, rendel_©, blaze, tamboon, shaqee, mrgoodboydatdat, ramla2002, Nilupa, spat, zimmermannn, bigone, Yuma, Hengki, harsono, Finger7, jayborre
 usman
User ID: 59
Threads: 138
Likes: 6,571 in 671 posts
Given Likes: 4974
01-19-2011, 04:45 AM
Can you explain ... which software is used to come up with this design calculation, as it is just a computer output/printout
[-] The following 3 users Like usman's post:3 users Like usman's post
  • Yasir, duazo2009, TAFATNEB
 duazo2009
Philippine
User ID: 16207
Threads: 5
Given Likes: 760
01-19-2011, 08:04 AM (This post was last modified: 01-19-2011, 08:32 AM by Dell_Brett.)
This is a combination of manual and software calculation and analysis, the Software being used is Etank 2000 from E-ware
[-] The following 1 user Likes duazo2009's post:1 user Likes duazo2009's post
  • usman
 mrgoodboydatdat
User ID: 28813
Threads: 14
Likes: 133 in 12 posts
Given Likes: 115
01-19-2011, 09:05 AM
(01-19-2011, 08:04 AM)duazo2009 Wrote: This is a combination of manual and software calculation and analysis, the Software being used is Etank 2000 from E-ware
Is the E-Tank give us the foundation loading data after mechanical design analysis?
[-] The following 1 user Likes mrgoodboydatdat's post:1 user Likes mrgoodboydatdat's post
  • TAFATNEB
 duazo2009
Philippine
User ID: 16207
Threads: 5
Given Likes: 760
01-19-2011, 11:59 AM (This post was last modified: 01-19-2011, 12:06 PM by kowheng.)
Yes, It will give you the foundation loading data depending on your input and it must be completely fill up depending on the required parameters.
Moderator Notes:
Please use "NEW REPLY" button or "Quick Reply" text editor at bottom next time. You may be warned for spamming if you kept replying with "REPLY" button (quoted text without good reason). Be careful, this is not the first time. You'll be warned for "SPAMMING", if you kept replying with quote text
[-] The following 2 users Like duazo2009's post:2 users Like duazo2009's post
  • mrgoodboydatdat, Umer.Aleem
02-09-2019, 08:02 AM
Size: 236 KB | Format: PDF & DWG
[-] The following 12 users Like kowheng's post:12 users Like kowheng's post
  • Andrew seah, jcbv, Dell_Brett, blaze, mgdario, zrilek, gulilero, joker™, oanm2000, moh_towhid, Sumatra, sacem
  Design of 5,000 Gal. Elevated Tank using Staad Pro. ranger 4 15,776 12-18-2012, 05:37 AM
Last Post: oram
  Detailed design calculation report manzoor_quadri 1 10,606 05-25-2012, 05:59 AM
Last Post: kirankumarklk
  Design of 5,000 Gal. Elevated Tank ( conical bottom ) using Staad Pro. ranger 1 10,163 03-12-2011, 01:29 AM
Last Post: ASEC
