Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem ETABS manual meshing
 rendel_©
Philippine
User ID: 1138
Threads: 122
Likes: 2,115 in 214 posts
Given Likes: 2687
Points:18,845 EP
11-03-2009, 02:00 PM
Can anybody here can give technique,tips or correct procedure in preparing a manual mesh in slab, in a fast way using etabs software.
Thanks in advance.
[-] The following 1 user Likes rendel_©'s post:1 user Likes rendel_©'s post
  • levanduy
 rohailiyaz
User ID: 925
Threads: 146
Likes: 1,152 in 117 posts
Given Likes: 733
Points:14,294 EP
11-03-2009, 03:20 PM
assign auto mesh
then go to edit.....mesh areas and divide the slab into lets say 4x4 squares
 rendel_©
Philippine
User ID: 1138
Threads: 122
Given Likes: 2687
Points:18,845 EP
11-03-2009, 05:46 PM
(11-03-2009, 03:20 PM)rohailiyaz Wrote: assign auto mesh
dividing the slab is not applicable for more the 4 sided area, so we need to sub-divide the irregular area by forming quadrilateral which is time consuming.
What I'm doing is I make a quadrilateral area that will occupy the whole slab area, then make a null line in all the corner,edges, opening column point in x and y direction. I will mesh the big quadrilateral by meshing the area with selected lines option, then delete the unnecessary area.
Anybody have better technique in manual meshing that can reduce the time.
[-] The following 4 users Like rendel_©'s post:4 users Like rendel_©'s post
  • timosi™, levanduy, Yasir, ruaumoko
 deviationz
User ID: 2031
Threads: 51
Likes: 546 in 107 posts
Given Likes: 72
Points:6,533 EP
11-10-2009, 01:27 AM
A model with manually meshed slab elements will always run faster than slab elements that have auto meshing using null lines.
 jaks
User ID: 2764
Threads: 15
Likes: 258 in 54 posts
Given Likes: 1225
Points:3,394 EP
11-10-2009, 06:20 AM
Hi, Guys
I had done meshing by using two softwares...
Import the dxf file into ROBOT, you have a meshing option there which will mesh the areas into rectangle/quadrilateral, from there saveas dxf again and import into ETABS. But after importing check for overalping areas if any. It gave good results and finer meshing for me.
You can try the above.
Jaks
[-] The following 5 users Like jaks's post:5 users Like jaks's post
  • Dell_Brett, rendel_©, levanduy, Yasir, ruaumoko
 tarugo
User ID: 201
Threads: 18
Likes: 415 in 55 posts
Given Likes: 154
Points:3,685 EP
11-10-2009, 01:50 PM
(11-10-2009, 06:20 AM)jaks Wrote: Hi, Guys
Jaks
"robot" meshing is good but in most cases you have to check for overlaps as you mentioned which create warnings and instability in ETABS. in my case i use adapt or ram concept for meshing but not so user-friendly compared to robot. depending on my building geometry i choose between robot and adapt on a case to case basis.
[-] The following 6 users Like tarugo's post:6 users Like tarugo's post
  • rendel_©, jaks, levanduy, sonidero, Yasir, ruaumoko
 kiwi2007
User ID: 12288
Likes: 0 in 0 posts
Given Likes: 1
Points:120 EP
02-02-2010, 03:40 AM
And how about meshing of membrane member, special for complex paragon shapes?
Rgds,
Kiwi
 jamessharp
User ID: 14962
Likes: 0 in 0 posts
Given Likes: 0
Points:197 EP
02-28-2010, 07:42 AM
hi guys i m tring since 4 days to use the automesh or even the manual mesh on slabs ( membrane) but i don`t know why these slabs are giving me a very high and un realistic displacemets (imean in miles ) even the model is very simple cos i was trying to compare betwen the three deferent slabs ( mesh . membrane ,plate )
when i dow the automesh for the membrane an i define the size of the element to 1 m
i got the loads distributed but the displacenets are not right ( somthing like 2000 miles )
funny isnt
i was wandering in any of you could give me a solution
(im using etabs 9.5)
 iceman84
User ID: 1829
Threads: 48
Likes: 419 in 154 posts
Given Likes: 402
Points:8,906 EP
02-28-2010, 12:45 PM
Use shell elements, not membrane elements.
 ssamis
User ID: 506
Threads: 7
Likes: 61 in 32 posts
Given Likes: 6
Points:973 EP
#10
02-28-2010, 01:14 PM
The program is right. Its over interpretration or ignorance. When U define slab for out of plane external forces as membrane it will only distribute load as per yeild line tributary area on edge beams and column but do not have any out of plan stiffness thats why it gives high displacement. There fore for displacement always define as plate or shell.
with regards
[-] The following 1 user Likes ssamis's post:1 user Likes ssamis's post
  • ruaumoko
Pages (2): 1 2 Next »
