Civil Engineering Association Forum Discussion Suggestion & Complains Archive Report Any Bug here
Thread Closed
Report Any Bug here
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 277
Likes: 21,143 in 2,346 posts
Given Likes: 4237
Points:549,114 EP
#591
07-10-2015, 01:26 PM
(07-09-2015, 09:15 AM)PinkPant Wrote: Yes, it's private message section.
While i was replying BennyPs message there was 2 quotes and while i press the preview button i cannot see complete view of replied message. I tried it again. It seems it's not working by me.
PinkPant
Try with 1 quote, there is limitation in reply with multi quote,
  • PinkPant
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 277
Given Likes: 4237
Points:549,114 EP
#592
07-10-2015, 01:28 PM
(07-08-2015, 09:19 PM)rigid_joint Wrote: I want to send an answer in this thread:
and forum returns that I can't. It says (Error label: 'no_permission')
Why is this happening?
Please check it now and if there is problem, post here and put screen shot,
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 277
Given Likes: 4237
Points:549,114 EP
#593
07-10-2015, 01:31 PM
(07-09-2015, 08:58 AM)f_slikken Wrote: Dear Admins,
Same as rigid_joint, I do have problems in sending queries or replies.
When I click on "FAQs, Q&A, comments ", it shows me an error so I can not ask question. Then when I post my question some where else, it gets deleted and I receive negative points?!?!? (dose not seem fair!!)
Can you please let me know how it works? If I do not have access to Q&A section, how can I ask questions without any consequences?
f_slikken.
I think there is a bug in points plug in, try now and tell me the report,
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 48
Likes: 4,953 in 633 posts
Given Likes: 3495
Points:18,510 EP
#594
07-13-2015, 01:41 AM
Given Thanks: 'number' not correct.
It is the number of the posts in the Received Thanks:.
concrete solution advocate
[-] The following 1 user Likes concreteok's post:1 user Likes concreteok's post
  • Administrator
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 277
Given Likes: 4237
Points:549,114 EP
#595
07-14-2015, 04:56 AM
(07-13-2015, 01:41 AM)concreteok Wrote: Given Thanks: 'number' not correct.
thanks for your report, it solved now.
[-] The following 3 users Like Administrator 's post:3 users Like Administrator 's post
  • Dell_Brett, concreteok, oanm2000
 rigid_joint
Senior Member
Jamaica
User ID: 6110
Threads: 16
Likes: 333 in 122 posts
Given Likes: 244
Points:8,861 EP
#596
07-20-2015, 01:58 PM (This post was last modified: 07-20-2015, 01:59 PM by rigid_joint.)
(07-10-2015, 01:28 PM)Administrator Wrote: Please check it now and if there is problem, post here and put screen shot,
For all the threads in [PROBLEM] section on every attempt on replying, forum returns this message :
 cace-01
User ID: 15651
Threads: 440
Likes: 10,522 in 867 posts
Given Likes: 7468
Points:65,522 EP
#597
07-20-2015, 03:52 PM
I am using postgen button to post in ebook section.  When I click the postgen it takes me to v2.3.1.  After filling all the details and pressing generate button i am copying the code and pasting it in respective new thread.  when i preview the same using preview post button i am seeing everything ok except the last line where it shows postgen 2.2.0.  However when i post it i am seeing many problems like bad size title and last line stating  This post has been made by CivilEA Post-Generator v2.2.0[url=http://postgen.civilea.com/index.html][/url] etc.  Kindly rectify if any thing is wrong in my procedure.  I cleared all cookies and using firefox browser. An example of my post can be seen in "http://forum.civilea.com/Thread-stresses-in-beams-plates-and-shells"
[-] The following 2 users Like cace-01's post:2 users Like cace-01's post
  • Administrator , Dell_Brett
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 277
Given Likes: 4237
Points:549,114 EP
#598
07-20-2015, 03:55 PM
(07-20-2015, 03:52 PM)cace-01 Wrote: I am using postgen button to post in ebook section.  When I click the postgen it takes me to v2.3.1.  After filling all the details and pressing generate button i am copying the code and pasting it in respective new thread.  when i preview the same using preview post button i am seeing everything ok except the last line where it shows postgen 2.2.0.  However when i post it i am seeing many problems like bad size title and last line stating  This post has been made by CivilEA Post-Generator v2.2.0[url=http://postgen.civilea.com/index.html][/url] etc.  Kindly rectify if any thing is wrong in my procedure.  I cleared all cookies and using firefox browser. An example of my post can be seen in "http://forum.civilea.com/Thread-stresses-in-beams-plates-and-shells"
Thanks for your report, we will review PG codes and fix it.
[-] The following 2 users Like Administrator 's post:2 users Like Administrator 's post
  • oanm2000, cace-01
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 277
Given Likes: 4237
Points:549,114 EP
#599
07-21-2015, 04:18 AM
I checked it, for me it works fine, specially footer is V2.3.1, due to CDN use please refresh PostGenerator Page by Ctrl+F5 and try again and tell me the report please.
  • cace-01
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 277
Given Likes: 4237
Points:549,114 EP
#600
07-21-2015, 04:19 AM
(07-20-2015, 01:58 PM)rigid_joint Wrote: For all the threads in [PROBLEM] section on every attempt on replying, forum returns this message :
Please check it now.
Users browsing this thread: 6 Guest(s)
Pages (63): « Previous 1 … 54 55 56 57 58 59 60 61 62 63 Next »
