Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Area Objects in Sap2000
 anrk_sk8er
User ID: 8262
Threads: 17
Likes: 38 in 13 posts
Given Likes: 42
Points:1,736 EP
10-12-2009, 06:53 PM
Hey people, i am trying to learn a little about this software, and i am getting a little confuse defining area objects
i dont know exactly the diference between the "shell", "plane", "asolid"
i really dont understand the options inside de shell
whats the differences between sheel thin/thick, plate thin/thick, membrane, and shell layered/nonlinear?
Plane is just used to model a state of stress or a state of strain in the program?
pls could anybody help me in understaing these differences?
[-] The following 2 users Like anrk_sk8er's post:2 users Like anrk_sk8er's post
  • Grunf, Grunf
 sonidero
User ID: 136
Threads: 10
Likes: 451 in 52 posts
Given Likes: 101
Points:5,093 EP
10-12-2009, 08:16 PM
(10-12-2009, 06:53 PM)anrk_sk8er Wrote: Hey people, i am trying to learn a little about this software, and i am getting a little confuse defining area objects
Let down:
Shell: An object that uses all the degrees of freedom. It is suitable to model walls, shells, etc, etc. It can handle time and usually gives you a degree of rigidity.
Plane: It has fewer degrees of freedom than the shell. It is used to model plane stress state, it supports all forces in its plane and rotations in the direction normal to its plane.
Membrane: Similar to the plane, but the difference stowage in supporting forces in the direction orthogonal to its plane, and rotations escapaz bear across its plane. In a nutshell, is the opposite to the element plane.
The option of using a thin shell is when you neglect the effects due to shear, but when are representative then you have to use the thick shell option, as it is in short items.
The shells with layers allow you to shape up sections such as slabs with steel reinforcement.
In conclusion, for a plane stress state the plane for you, for you save computation time and especially if you are interested in now.
Check the manuals including SAP and ETABS, there's some more detail the case.
[-] The following 8 users Like sonidero's post:8 users Like sonidero's post
  • Dell_Brett, Dell_Brett, timosi™, timosi™, levanduy, levanduy, Grunf, Grunf
 romuldzenon
User ID: 8975
Likes: 0 in 0 posts
Given Likes: 0
Points:178 EP
10-13-2009, 10:24 AM
Hi,
I think u should visit proper website or take a proper book,
if possible than take class from proper classes
 sonidero
User ID: 136
Threads: 10
Given Likes: 101
Points:5,093 EP
10-13-2009, 03:45 PM
(10-13-2009, 10:24 AM)romuldzenon Wrote: Hi,
It's also a good idea to consult specialized books. But remember that each program handles different types of elements in their own way, what I described was for the exclusive use of SAP, so you should always check the manuals for each program, of course, also be informed in general terms.
[-] The following 2 users Like sonidero's post:2 users Like sonidero's post
  • timosi™, timosi™
 juice
User ID: 108
Threads: 8
Likes: 362 in 68 posts
Given Likes: 176
Points:4,213 EP
10-13-2009, 09:40 PM
Hi romuldzenon, I will appreciate if you can direct the member who asked for help to useful links, books, etc. Not just telling the member to take proper classes....
juice
[-] The following 10 users Like juice's post:10 users Like juice's post
  • Dell_Brett, Dell_Brett, Grunf, Grunf, levanduy, levanduy, kamran, kamran, timosi™, timosi™
 Haseeb Jamal
User ID: 9152
Threads: 34
Likes: 674 in 72 posts
Given Likes: 125
Points:4,682 EP
10-15-2009, 03:09 AM (This post was last modified: 10-15-2009, 09:42 PM by kamran.)
Here is a link to video tutorials about SAP2000. Here you will find basic videos and advanced ones too
SAP2000 Video Tutorials
[-] The following 4 users Like Haseeb Jamal's post:4 users Like Haseeb Jamal's post
  • simanta, simanta, Civil Engineer, abtcivileng
