Foundation: Telecom, Transmission, Guyed Tower, Pole Footing - TIA 222F & ACI
Single Footing Design - Telecom, Transmission & Guyed Tower & Pole - TIA 222F & ACI
[Image: 29003842113651014670.jpg]
Its a Excel Sheet for Single Footing Design for Telecomm, Transmission & Guyed Tower
& Pole according TIA 222F & ACI. Prepared by Engr Jemi Astimo (Tower design Engineer
in Indonesia, Good designer). Slight modification has been made afterwards.
Here Geotechnical Design of Footing has been considered mainly. Not structural Design, as Single footing of Telecomm tower/Pole is designed considering upward force and sliding force,
rather than traditional downward force.
Excel sheet or computer program is not always available for single footing design is placed
considering uplift and shliding force.
If you have time then review and post comment. Everyone will be helped.
Anyway, Structural Design of footing is normal. Though attaching another excel sheet
for footing structural design by daniel T Li. U can se that Excel sheet made by Daniel T Li
is not all time fit for all types of footing, specially footing with uplift force and sliding.
Daniel T Li didn't made any check for uplift force and sliding.. Another excel file has
been added to remove excel cell password. One Prokon Single footing file has been
added... which will show same result as well with the excel sheet.
Mohammad Mahfuzur Rahman,
mahfuzbangla :
Would you please let me know what the conventional way is to strengthen the tower foundation in Asia to resist the uplift?
We deal with telecommunication tower always with the additional antennas adding onto the existing tower structure.
[-] The following 1 user says Thank You to junhe898 for this post:
  • telecivil
provide counter weight for uplift / tilt problems.
[-] The following 2 users say Thank You to parhyang for this post:
  • GROUT, bigone
I believe generally to resist uplift the simplest manner in which to accomplish this is simply to provide additional weight on top of existing footings and provide more resistance.
Alternatively deepening i would assume.
[-] The following 3 users say Thank You to durden for this post:
  • Diquan, bigone, nickycruz
Mirror link of post#1:
ps:including 4 files
1)Password_To_Unprotect_Excel_Sheet.xla
2)Single Footing Design - Telecomm, Transmission & Guyed Tower & Pole - TIA 222F & ACI.xls
3)Single Footing Prokon - 03-03-10.C15.txt
4)Single Footing Structural Design - Daniel T Li - Unlocked.xls
Regards.
Software/Book in the links of this post is for evaluational and testing purposes, you must not use it for any commercial purpose!!
If you benefit from using this Software/Book, you have to buy a licence!!
[-] The following 21 users say Thank You to vsa2010 for this post:
  • Dell_Brett, TAFATNEB, Grunf, quatermain, concreteok, jacs127, ting tsai huang, malc, Jackass, tluc, duazo2009, DamaD, mahfuzbangla, dinu69in, nigema, kalayil78, realbabilu, portal61, SCREAM7890, oanm2000, bigone
Compilation of Footing Design Spreadsheets:
[Image: 58164686366531360960.jpg]
581 KB
[-] The following 29 users say Thank You to Dell_Brett for this post:
  • Andrew seah, mahyarov, shadabg, pezhmankhan, bigone, isurya, ting tsai huang, ska51, gulilero, odiclas, Diquan, oanm2000, kowheng, malc, we_mbm, gundis, cardinal85, nickycruz, TAFATNEB, Ambition, jaks, nibbi, blaze, PinkPant, chenamoy, hignacio43, geomahesh, Rodmo376, legarleon
[-] The following 8 users say Thank You to pezhmankhan for this post:
  • oram, slowet, Dell_Brett, ykhackhack, lednar_ved, nickycruz, subin91, legarleon
Foundation: Combined Trapezoidal Footing Design by JEC robertsas 2 3,610 03-26-2014, 11:39 AM
Foundation: Combined Rectangular Footing Design by JEC robertsas 2 3,885 03-26-2014, 11:37 AM
Pole Foundation Analysis usman 1 4,802 03-15-2012, 04:44 PM
Last Post: Diquan
