Civil Engineering Association eBooks Structural Books Steel Design of Steel Structures to Eurocodes
 carolinandra
Colombia
User ID: 12281
Threads: 112
Likes: 2,885 in 157 posts
Given Likes: 1333
Points:17,730 EP
01-14-2019, 12:57 PM
Author(s)/Editor(s): Ioannis Vayas, John Ermopoulos, George Ioannidis | Size: 25.1 MB | Format: PDF | Quality: Original preprint | Publisher: Springer | Year: 2019 | pages: 627 | ISBN: ISBN-10: 3319954733 ISBN-13: 978-3319954738
[Image: 76229048029391549095.jpg]
This textbook describes the rules for the design of steel and composite building structures according to Eurocodes, covering the structure as a whole, as well as the design of individual structural components and connections. It addresses the following topics: the basis of design in the Eurocodes framework; the loads applied to building structures; the load combinations for the various limit states of design and the main steel properties and steel fabrication methods; the models and methods of structural analysis in combination with the structural imperfections and the cross-section classification according to compactness; the cross-section resistances when subjected to axial and shear forces, bending or torsional moments and to combinations of the above; component design and more specifically the design of components sensitive to instability phenomena, such as flexural, torsional and lateral-torsional buckling (a section is devoted to composite beams); the design of connections and joints executed by bolting or welding, including beam to column connections in frame structures; and alternative configurations to be considered during the conceptual design phase for various types of single or multi-storey buildings, and the design of crane supporting beams. In addition, the fabrication and erection procedures, as well as the related quality requirements and the quality control methods are extensively discussed (including the procedures for bolting, welding and surface protection). The book is supplemented by more than fifty numerical examples that explain in detail the appropriate procedures to deal with each particular problem in the design of steel structures in accordance with Eurocodes. The book is an ideal learning resource for students of structural engineering, as well as a valuable reference for practicing engineers who perform designs on basis of Eurocodes.
[-] The following 43 users Like carolinandra's post:43 users Like carolinandra's post
  • blaze, melekeen, agelos100, jcbv, milova, amindoxiti, vvvv, allagui10, munycamsec, oanm2000, rezart, zrilek, febo927, jfjdm, hapsea, cace-01, Nita1391, cordoba123, struceng, K.Lee, pedzaquino, tomtumx, cheosmith, rami1976, PinkPant, gianniorlati, dizz, avge, Aviator, Andrew seah, gulilero, Agent66, malc, pram, red_pool61, apocalipse, Dell_Brett, tuanpecc1, subin91, albani, er.shyams, cristi, kowheng
  Steel Structures Design; For Lateral and Vertical Forces carolinandra 3 3,388 01-07-2022, 02:44 AM
Last Post: Veggeta
  Steel Building Design: Concise Eurocodes jamildear4u 3 4,107 12-02-2021, 02:23 PM
Last Post: babakfeyzi
  Ductile Design of Steel Structures 2nd lamkin 8 6,131 09-06-2021, 04:15 AM
  Ultimate Limit State Design of Steel-Plated Structures apocalipse 2 2,364 11-19-2020, 03:16 PM
Last Post: Kurucz
  ECCS - European Recommendations for the Design of Simple Joints in Steel Structures agelos100 0 1,284 05-14-2020, 09:19 AM
Last Post: agelos100
  Advanced Steel Design of Structures carolinandra 1 1,839 01-08-2020, 08:58 AM
Last Post: kirankumarklk
  Design of Joints in Steel and Composite Structures amindoxiti 3 2,872 12-17-2019, 06:53 AM
