Tall building design: steel, concrete, and composite systems
Author(s)/Editor(s): Bungale S. Taranath | Size: 37 MB | Format: PDF | Quality: Original preprint | Publisher: CRC Press | Year: 2016 | pages: 933 | ISBN: 9781315356860, 9781315374468
[Image: 67407780380136118646.jpg]
Addresses the Question Frequently Proposed to the Designer by Architects: "Can We Do This?
Offering guidance on how to use code-based procedures while at the same time providing an understanding of why provisions are necessary, Tall Building Design: Steel, Concrete, and Composite Systems methodically explores the structural behavior of steel, concrete, and composite members and systems. This text establishes the notion that design is a creative process, and not just an execution of framing proposals. It cultivates imaginative approaches by presenting examples specifically related to essential building codes and standards. Tying together precision and accuracy―it also bridges the gap between two design approaches―one based on initiative skill and the other based on computer skill.
The book explains loads and load combinations typically used in building design, explores methods for determining design wind loads using the provisions of ASCE 7-10, and examines wind tunnel procedures. It defines conceptual seismic design, as the avoidance or minimization of problems created by the effects of seismic excitation. It introduces the concept of performance-based design (PBD). It also addresses serviceability considerations, prediction of tall building motions, damping devices, seismic isolation, blast-resistant design, and progressive collapse. The final chapters explain gravity and lateral systems for steel, concrete, and composite buildings.
The Book Also Considers:
Preliminary analysis and design techniques The structural rehabilitation of seismically vulnerable steel and concrete buildings Design differences between code-sponsored approaches The concept of ductility trade-off for strength
Tall Building Design: Steel, Concrete, and Composite Systems is a structural design guide and reference for practicing engineers and educators, as well as recent graduates entering the structural engineering profession. This text examines all major concrete, steel, and composite building systems, and uses the most up-to-date building codes.
Table of contents :
Content: Ch. 1. Loads on building structures --
ch. 2. Wind loads --
ch. 3. Earthquake effects on buildings --
ch. 4. Wind load analysis of buildings --
ch. 5. Seismic design with particular reference to ASCE 7-10 seismic provisions --
ch. 6. Performance-based design --
ch. 7. Preliminary calculations to ensure validity of computer analysis --
ch. 8. Seismic evaluation and rehabilitation of existing buildings --
ch. 9. Special topics --
ch. 10. Torsion --
ch. 11. Seismic design : a pictorial review --
ch. 12. Steel buildings : bolted and welded connections, gravity, and lateral load-resisting systems and details --
ch. 13. Composite buildings : structural system and details.
[Image: comments.png]
Thanks to Original Uploader
a- Follow the Forum Rules.
for uploadboy link
[-] The following 17 users say Thank You to rami1976 for this post:
  • jcbv, mgdario, cheosmith, Aviator, oanm2000, amindoxiti, gulilero, promo8, hatkam, zrilek, rezart, apocalipse, zego2000, hodzicemir, Dell_Brett, TurboXUser, babak
[-] The following 6 users say Thank You to Wijono for this post:
  • oanm2000, hodzicemir, K.Lee, Dell_Brett, carolinandra, babak
Building Structures Illustrated: Patterns, Systems, and Design asim99 1 2,186 11-22-2018, 09:26 PM
Last Post: carolinandra
SCI P287: Design of Composite Beams using Precast Concrete Slabs ir_71 2 3,190 04-25-2018, 11:26 PM
Last Post: gulilero
Tall and Super Tall Buildings: Planning and Design amindoxiti 0 1,105 02-10-2018, 10:04 AM
Structural Analysis and Design of Tall Buildings: Steel and Composite Construction mybest 8 7,911 03-28-2017, 08:06 AM
Last Post: Wijono
Tall Buildings: Structural Systems and Aerodynamic Form asim99 3 3,793 03-18-2017, 09:39 AM
Last Post: cace-01
