Principles of Structural Design: Wood, Steel, and Concrete, Second Edition
Author: Ram S. Gupta | Size: 8 MB | Format: PDF | Quality: Unspecified | Publisher: CRC Press | Year: 2014 | pages: 528 | ISBN: 9781466552319, 146655231X
[Image: 46252169849677536149.jpg]
A structural design book with a code-connected focus, Principles of Structural Design: Wood, Steel, and Concrete, Second Edition introduces the principles and practices of structural design. This book covers the section properties, design values, reference tables, and other design aids required to accomplish complete structural designs in accordance with the codes.
What’s New in This Edition:
Reflects all the latest revised codes and standards
The text material has been thoroughly reviewed and expanded, including a new chapter on concrete design
Suitable for combined design coursework in wood, steel, and concrete
Includes all essential material—the section properties, design values, reference tables, and other design aids required to accomplish complete structural designs according to the codes
This book uses the LRFD basis of design for all structures
This updated edition has been expanded into 17 chapters and is divided into four parts. The first section of the book explains load and resistance factor design, and explores a unified approach to design. The second section covers wood design and specifically examines wood structures. It highlights sawn lumber, glued laminated timber, and structural composite/veneer lumber. The third section examines steel structures. It addresses the AISC 2010 revisions to the sectional properties of certain structural elements, as well as changes in the procedure to design the slip-critical connection. The final section includes a chapter on T beams and introduces doubly reinforced beams.
Principles of Structural Design: Wood, Steel, and Concrete, Second Edition was designed to be used for joint coursework in wood, steel, and concrete design.
Thanks to Original Uploader
[-] The following 11 users say Thank You to sinamaleki for this post:
  • oanm2000, eliseo.as, ykhackhack, bridgeengineer, PinkPant, ruaumoko, jonny78, malc, techno, nickycruz, carolinandra
[-] The following 6 users say Thank You to febo927 for this post:
  • rendel_©, zrilek, jcbv, oanm2000, PinkPant, simanta
[-] The following 11 users say Thank You to rami1976 for this post:
  • pedzaquino, Dell_Brett, dwrred, hatkam, jcbv, vvvv, Nita1391, blaze, oanm2000, er.shyams, konstobo
Structural Design from First Principles cace-01 0 842 04-05-2018, 02:26 PM
Last Post: cace-01
Elementary Behaviour of Composite Steel and Concrete Structural Members abudabeeja 7 5,913 08-24-2016, 04:23 AM
Last Post: gulilero
Principles of Structure, Fifth Edition Jackass 1 1,889 06-05-2016, 02:50 AM
Last Post: f_slikken
Structural Design: A Practical Guide for Architects, 2nd Edition ibg0203 0 1,127 04-10-2016, 06:19 PM
Last Post: ibg0203
Principles of Structural Design abudabeeja 7 7,443 09-02-2015, 04:44 PM
Last Post: ibg0203
