Civil Engineering Association eBooks Journals, Papers and Presentations Evaluation of dynamic properties of site and Response of Motion Si mulator Foundation
08-11-2014, 10:49 AM
Author: P. Anbazhagan * , T.G. Sitharam + , G.L. Sivakumar Babu and More Ramulu | Size: 122 KB | Format: PDF | Quality: Unspecified | Publisher: Department of Civil Engineering, Indi an Institute of Science, Bangalore | pages: 10
Geotechnical parameters such as shear wave velocity and shear modulus are very important parameters in ground response analysis. The dynamic properties of foundation material below the three axes motion simulator are evaluated using the Block vibration test, Multichannel Analysis of Surface Waves (MASW) and a seismograph. This paper presents the measurements of dynamic properties using Block vibration test and MASW. Paper also present the response of foundation material due to local site condition using SHAKE2000 and vibration measurements for a passive source. Vibration characteristics of foundation material have been monitored by a seismograph with tri-axial sensors to measure the peak particle velocity in all the three directions from the passive sources such
as generator, pump house and industrial Buildings which are located at about 70m to 200m from the proposed motion simulator.
  • vardan, malc, PinkPant, gulilero, shadabg
  Evaluation Of Earthquake Response Analysis Methods For Low - Rise Base Isolated B. TAFATNEB 0 5,678 09-05-2014, 01:46 PM
  Dynamic response of bare steel concrete under human rhythmic activities TAFATNEB 0 3,835 08-14-2014, 07:39 AM
  Dynamic Stiffness and Damping of a Shallow Foundation from Forced Vibration of a Fiel TAFATNEB 0 3,531 08-11-2014, 10:20 AM
  DYNAMIC RESPONSE OF HIGH RISE STRUCTURES UNDER THE INFLUENCE OF DISCRETE STAGGERED SH TAFATNEB 0 4,226 05-30-2014, 01:55 PM
  Seismic evaluation of fluid-elevated tank-foundation/soil systems in frequency domain TAFATNEB 0 3,960 05-10-2014, 08:32 AM
  EARTHQUAKE RESISTANCE OF STRUCTURES AND DYNAMIC RESPONSE USING LARGE FACILITIES EXPER TAFATNEB 0 3,928 04-23-2014, 03:44 PM
  NONLINEARITY IN SEISMIC SITE EFFECTS EVALUATION TAFATNEB 0 3,452 04-12-2014, 02:52 PM
