Autodesk Advanced Concrete 2015 x64
Current time: 05-22-2018, 04:19 PM
Author: BennyP
Replies 4
Views 6824
[Image: 59167463880027329579.gif]
[Image: 79880836452337316136.gif]
[Image: 43427311498607138770.gif]
Advance Concrete software for concrete design and detailing is built on the AutoCAD platform. Work with easy-to-use, comprehensive tools to help accelerate more accurate modeling and automate the creation of construction drawings and deliverables. Interoperability with Revit software supports a more connected Building Information Modeling (BIM) workflow.
Reinforcement modeling and detailing
Use a variety of tools to reinforce structural elements, including cast-in-place concrete, precast concrete, and special construction elements.
•Detail bars and meshes freely, directly on 2D drawings, as Advance Concrete creates and maintains a 3D model
•Select from a library of predefined bar shapes
•Assign parametric reinforcement attributes for each object (beams, columns, openings)
•Automate the placement of reinforcement bars and keep drawings up-to-date when models are modified
•Automatically optimize mesh and bent mesh reinforcements
•Create and visualize 3D reinforcement cages, and check clashes more easily
All you need is to enter the Autodesk site, to search for "concrete"
Look at the screenshot - the file is 1.0 GB
[Image: 91119976283974823563.gif]
  • raja, learner20, emmi, araza023, Diquan, oanm2000, drewpt, engiman27, ali akbar
Autodesk Advance Concrete 2015.1
[Image: 49084909652318732109.gif]
[-] The following 13 users say Thank You to BennyP for this post:
  • Dell_Brett, mgdario, highcivil, zrilek, bridgeengineer, melekeen, PinkPant, rodleyzed, oanm2000, simanta, lissics, malc, dquan373
Product key for v2015.1 - 960G2.
[-] The following 2 users say Thank You to gafi for this post:
  • bridgeengineer, lissics
Nice to see you translate what every one can see in the screenshot. For what you think I posted the screenshot, for giving you the opportunity to add a post ? Or you think I forgot ?
Autodesk AutoCAD 2015 (x86/x64) BennyP 4 8,203 06-01-2017, 03:40 PM
Last Post: lesgiu
Autodesk Revit Extensions 2015 KhaLed-S.E 0 1,468 03-28-2015, 09:53 AM
Last Post: KhaLed-S.E
Autodesk AutoCAD 2015 Service Pack 2 rami1976 0 1,510 03-22-2015, 06:16 PM
Autodesk AutoCAD Structural Detailing 2015 64bit BennyP 1 7,251 03-16-2015, 09:45 AM
Last Post: gianniorlati
Autodesk AutoCAD Civil 3D 2015 x64 BennyP 2 3,704 03-10-2015, 10:32 PM
